On 7/12/2023 at 3:02 PM, Everest said:
Thanks for the compliment
Your truck setup looks tough. I like the wheel/tire choice too. What size tires you running?
Also how clean do the red calipers stay? Was thinking of doing the same thing as well as doing the red row hooks
Damn, I just painted my red tow hooks gloss black!
I finally did a thing.  Duratracs in 285/75r18.  No lift or level, yet.  ReadyLift 2" kit is sitting in the garage because I don't have the majority of my tools.  Only basic tools in case of roadside emergency.  Just moved from California to Florida, but furniture hasn't been delivered yet.  Had slight rub on mud flaps so I replaced them with the McGaughy's delete kit (not shown because they arrived a few days after the pic was taken).  Truck needed new tires when I reached 50k miles.
Question:  Should I get fender flares?  Been debating this question for 3 years.  I'm considering the ones with the flat spot in the midis like the Sierras have.
Edited by Transient
What about the ZR2 Fender Flares without the Flat?
Honestly, I haven't even looked at them
Edit:  just to a look.  I don't think they're feasible.  The front of the fenders don't go as far down on the ZR2.  I don't think the flares will work.
Edited by Transient
I thought I read someone had done it, but perhaps they made some changes of some sort to allow it?  I do think I recall something about removing the mudflap?
On 7/11/2023 at 6:25 PM, Everest said:
I just finished doing this to my 2020 Sierra x31
just remember the angles you see with the truck sitting still may not be the angles that are troublesome. It is when the front of the vehicle travels up llike when going over a bridge and the suspension travels up and down or bounces, and if the bounces are  too violent the suspension will max the angles out as the front end of the truck travels up in the air, causing possibly a fracture in the ball joint
With that being said, I would like to point you in the direction of american trucks.com. That is where I found a great deal on a set of upper control arms. They have a lot of open box products sometimes at half the cost I was able to find a set of FAbtech upper control arms that normally were 300 and something dollars and I was able to get them taxes shipped and all for 136 so I jumped on it. I also upgraded the shocks all the way around with the Billstein 5100 adjustable shocks truck rides so much better with those shocks and also gives you the option to add up to 2 1/2 inches of lift to the front. So what I did was chose option for 2 1/2 inch lift, and I and paired that with the 2 inch upper strut spacer leveling kit that I had already put on the truck so now I am sitting at roughly 4 to 4 1/2 inches and the angles on my upper control arms look great everything aligned perfectly then added a 1 1/2 inch block in the back.
As far as the tire size I went with the 35x11. 50x 20 and have no rubbing  but when I put the half inch spacers to push the tires out a bit I did get just a small amount of rub at 90-100 percent turn. I will
post pictures to give you an idea of my set up. Good luck on yours. Just wanted to share some helpful information.
Have you had any problems with your CV angles? I’m looking to do this setup.
Truck has 70k miles and lift has been on it for 10k and so far no issues. 👍
Your truck looks good. I love the color and tires. I wouldn't add the flares if it were me. I think that the truck(s) looks better without them. Just my $0.02.
Awesome glad to hear it! Thank you.
Thanks for the kind words and honest opinion
Your truck looks good. Fender flairs aren’t needed unless your tires are slinging gravel or mud on to the side of your truck. They don’t add much if just for looks imo.
Thank you for sharing your opinion
I think your truck looks bada** as is. I would not bother with fender flares. I really like my Duratracs.
Thanks.  I've heard you and appreciate your opinion.  I have decided to not get the fender flares.  I was never sure which way I was going with that and needed to hear what others thought.
Raceline Ryno 17x9 -12 with Mickey Thompson Baja Boss A/T LT 315/70R 17 (35x12.5)
Cognito 3" lift (2" blocks in back) Cognito UCA with Fox 2.0 Coilovers -I did add another 3/4" of lift by adjusting the coilovers
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
