All, I really need your help. I am reading your experiences and I can relate where some people are not halo with the new 2019 Silverado ride quality. I am miserable in my 2019 Silverado LT. It is very bouncy. I was thinking to upgrade to the Trailboss or LTZ for a better suspension and ride quality and now I don’t know. I have taken my truck to the dealership twice and they say nothing is wrong with it. Can anyone tell me if the suspension is better in the higher trim levels than then LT?
I test drove my first at4. It drove like garbage. I was getting off the expressway and the back was bouncing to the left. I was thinking it was the at4 package. I was the first at4 I saw in October. I drove the Denali next it drove great. The next morning the dealer told me they got a trial boss in. I drove it and the let me drive it throw a construction lot that was in rough shape. It drove amazing. I the end I ordered the at4. I took delivery in January.
The first at4 definitely had a problem. Never found out why. I was told packing blocks could of been left in the rear suspension. But I dont know.
Good luck!
My LT Z71 is as smooth as silk.
Have you checked the air pressure in the tires?
Also, is yours a Z71 too?
At any rate, I'm sorry yours is so bouncy.
Good luck.
The short answer is no. A Trailboss or LTZ isn’t going to ride any different from your LT, necessarily. It comes down to suspension package, tires and tire size. Now the Trailboss only comes one way suspension-wise (and is said to have better shocks), but the rest of the Chevy line up can either have the base suspension, Z71 or NHT (max trailering).
Edited by OnTheReel
Welcome to the club, Michael. My RST can ride a little bouncy in the front but harsh in the rear.
Many of us are waiting for Bilstein to release the 4600 or 5100 shocks for the T1, which should be in the next month or two.
I’m with you. After having a Ram before this truck it bothers me everyday and takes the joy out of driving the new truck. I can’t wait u til the aftermarket catches up and I can do something to fix this horrible ride. It’s the only thing worse than the transmission tuning.
Is this your first leaf-sprung truck? Leaf springs are very bouncy on highways in construction zones. I drove a loaner silvy when I had an avalanche in for service, and the same stretch of beat up highway I used for work was almost dangerous in the truck going 75 vs the avy which had no issue. Rear was all over the place. Most full size suvs are coils vs leafs since they dont typically haul as much. A bit of weight in the bed to compress the springs would probably make a big difference; a topper or a tonneau is a choice...
Sent from my SM-T580 using Tapatalk
Don't forget to check if there is a block near the rear Spring for transport purposes! The dealer told me sometimes they forget to take those out.
Bingo!  What you said about the Avalanche rings true.....had 3 of them and there isn't any Silverado that can compare with their rear coil spring suspension.  Aside from lack of coil springs a Silverados "bouncy" ride over bumps is due to gravity. Put the Silverado, which base is also lighter than an Avalanche, on a 400 lb diet and it rebounds higher when it hits a bump or rough highway with weatherstrips. Lightweight beds and 4 cyl engines make for a bigger bounce.
First week I was disappointed with the rougher ride of the '19 RST with 285 R22 50s. Reducing the over inflation to proper 35 psi helped a bit and tires make it corner like a cat with no rear end breakaway but there was definitely more rear axle bounce than my '16 Z71. Now the it rides smooth at all speeds because I figured out what my problem was. My '16 with sports bar and rubber bed mat also had two Swingaway saddle bags mounted in the bed which I removed intending to place in the '19 along with the 80 - 100 lb rubber bed mat. The mat fit was 99% and required only a small piece to be trimmed, but the Swingaways were a no go.......old mounts would have blocked bed side lighting and intruded into the bed area, so they sat in my garage for over a week waiting to be unloaded. I had forgotten that there was at least 100 lbs of crap, trailer hitches, compressor pumps, etc in each one.....so much that the cases were cracking........threw them out and loaded the contents into milk crates which now fit nicely behind the wheel wells in the wider bed. Seems the 200 lbs behind the wheels (and threw in a floor jack for good measure) did it ....that combined with the existing 100 lbs for the sports bar and tonneau cover over the front and top of the bed did the trick, now the rear not only grabs tight in turns, but no more rear axle hops on bumps. And the ride is now as good, probably better, than the '16. Might screw up mileage a bit but I'll gladly sacrifice gasoline for comfort ......a better dead weight approach than sticking relatives in the rear seat.
Going to throw in the Bielsteins for good measure when they come out.
exactly what he said, and no trucks don't ride like this - my 13 F-150 XLT 4x4 crew cab road like a dream I currently have 19 Silverado LT 4x4 crew cab and it ride so bad I feel like every time I go over rail road tracks it bounce and feel like I lost control
Just wait till the Bilstein comes out - The 1999 Ram 2500 would fit I think I seen a YouTube video on that but can't find it to save my life
okay the video was about lowering kit so scratch the shocks thing (my bad)
15 hours ago, Michael Gardner said:
 I am miserable in my 2019 Silverado LT. It is very bouncy. ...
Which tire/wheel combo did you get?  Maybe your salesman could let you take a similar truck with a different tire/wheel combo for a ride.  Tires alone can make a hell of a difference.
My LT Z71's ride is fairly decent, and is MUCH firmer ride than the '19 ram I test drove.  The ram seemed to be very "boaty".
Hope you get it sorted out.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
