30 minutes ago, vancealot29 said:
So, I was quoted something like $350 for a 2 inch front level with alignment.  Will these new shocks do the same?  How much more $ are you talking?  I have no problem waiting if that is the case.
Thanks for the info!
I got a $680 quote for a 1.5 level installed with alignment. I need to call a few other shops.
But the shocks themselves are about $110 each. That's about the price of a quality leveling kit, so why not add another $110 and get a much improved ride over the Ranchos WITH a level.
5100 Leveling Shocks can go up to 2.75", I believe.
Thank you, good info.
I looked back at my notes, and the quote for the 2 inch level with alignment was $399.
So, ~$220ish for the parts, do you have an idea of what the quoted install time is for the labor charge, or is this something simple enough that I can do in my garage?  I would assume the labor charge would be at least two hours, or another ~$200 on top.  Is an alignment still necessary on top of that?
Sorry for all the Q's, but this just seems like a better bang for my (400) buck(s).
Thanks for the help!
I think it's definitely better bang for your buck, especially if you have the Ranchos. The Bilsteins up front will perform much better. So, yeah, why not spend 25-30% more and get a better long-term product?
You'll need an alignment if you go with the Bilsteins, yes. I'm sure you can install them yourself if you have the right tools and a little mechanical know-how. There's a few YouTube videos out there showing how to do this. It's a little more complicated than just putting a leveling block in, that's for sure.
9 hours ago, SamDSJR said:
So my truck is a Max Tow Package truck. Do you think this will modify my GVWR? I would think that the springs & the larger axle have more to do with that than the shocks. Thoughts?
The shocks won’t affect your GVWR or weight carrying capacity in any way.
Awesome. Thanks for the input.
How much can you tow with a Max PKG ??....thanks?
I had a set of Bilsteins front/rear on my previous truck (‘09 taco) for 9-10 years of abuse and they held up great.
Can’t comment with longevity on a full size truck, but anything HALF as good as on a mid-size = amazing.
On 8/15/2019 at 12:38 PM, Sin City Trail Boss said:
Interesting.
How will the 5100s compare to my stock Z71 Rancho shocks that come with the Trail Boss?
Installed Bilsteins on my 2014 Ext cab. Did not like them thought too much compression damping. If I wear out the Ranchos on my 2019 will replace with same. Am very happy with the ride and want to keep it that way.
I got tired of waiting and ordered 4 Eibach’s for $389 no tax and free shipping. Should arrive early next week.
yeah I talked to eibach today and their pro truck sport shocks are available now, but not springs....jan for those, and june for coilover kit....still good deal, I am 20 miles away from them so I cant escape tax....still debating between kings
the sales guy said ride quality isn't effected at all however you set ride height on fronts but find it hard to believe
snuff are you just gonna run stock springs with yours?
the stock suspension really does suck on these trucks, even on concrete freeway, cant imagine if I actually took it offroad
Edited by Dunn
My configuration is 11,400lbs. 2019 5.3 w/Max Tow, 3.42, 4x4, 8-Speed tranny, Crew Cab Short Bed, 18" rims.
Just had 4 new bilstein 4600s installed on my 2500 Z71 as I am keeping my stock ride height for now.  Very pleased.
Yes - I am going to run stock springs and see how it goes.
Edited by Snuff
13 minutes ago, Snuff said:
Yes - I am going to run sticks springs and see how it goes.
Look forward to hearing your thoughts on the Eibachs.
    LCH14
    LCH14
  • Who's Online   1 Member, 0 Anonymous, 1,589 Guests (See full list)
    • The 92-95 SCPI spider injectors are notoriously problematic and hard to source new replacements. I’d pull the intake manifold first to inspect cracked lines and brittle plastic legs before dropping $350 on a rebuild. The 1.5 OBD system only offers limited data, no misfire tracking, which is normal for this 1995 model. Enjoy the project!
    • Yea a fluid change is in order here. Honestly, your transmission didn’t even get hot. During the summer in stop and go traffic I’ve seen my 8l80 get up to 216 and it was still shifting smoothly.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
