Anyone Have the Brembo 6-Piston Calipers Installed?
Does anyone have the Brembo 6-piston brake calipers installed before or after the fact?
My previous vehicle had factory Brembo brakes and it was awesome. It had great bite with no fuss. Anytime i get in a vehicle without Brembo brakes, I notice the difference. The default brakes on this truck sometimes feel inadequate to me. If the Brembo package wasn't so expensive, i would probably go for it.
Thinking about getting the OEM Brembos..... I looked at Brembos web site, and it looks like they dont have a version available that isnt the OEM style... Id prefer to have slotted and drilled. Will def get them if I get turbos added.. until then, I think Ill be OK with stocks. But they are tempting.
Yeah, Brembos are awesome. Would get them if they weren't so pricey. $2,096.25 for the front and $431.25 for the rear on shopchevyparts.com seems a bit much. Not sure what is special about the rears though, looks like it's only red paint. If i did get them, it will probably be just the fronts
They are pretty awesome. I’ve been eyeballing them. Would definitely only upgrade the fronts too.
if they were $1000, maybe $1500, I might bite. But $2000 is just too much. The factory brakes are pretty darn good. The factory pads are probably designed to offer the best braking performance along with low dusting. You could probably upgrade your pads and have even better stopping without changing the calipers.
Pricing is right in line with what Wilwoods are - so I don’t think they’re overpriced. Expensive yes but not overly, especially for the rear. I’ve had the Wilwood 16” kits and they performed awesome - brembo with a completely factory fit would be even better.
You learn something new everyday ?. This is my first time hearing about Wilwood, had to google them. They look a lot like Brembos with a Wilwood inscription. Then again, that statement probably goes for any multi piston caliper brake.
I wonder how much the factory default kit is worth. Maybe, that can help offset the cost for the Brembos.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
