Purchase two brand new Denali trucks with the 10-speed transmission diesel motors and having a problem with hard shifting come especially as ID accelerate to a stop and the truck lunges forward and if I'm not careful feel like I could hit somebody in a crosswalk. I know some of these trucks take time to learn owner's shifting habits but seems to be a little extreme and worried about taking it into the dealer to be told that the off-road fuel might have done this do to my other vehicle losing warranty because the dealership said I had off-road fuel in the truck which I've been told by the EPA doesn't even exist anymore since 2012 I know it's a little bit of a sarcastic comment but has anybody had problems with lunging
Someone said in another thread that these are not Allison transmissions.. Something about them being jointly designed/manufactured by Ford and GM.
I believe they were talking about the gas 1500’s
The transmission for the HD's was co-developed by GM and Allison (built to Allison specs) but it is built by GM. It says Allison because it meets Allison specs and they passed their testing. Therefore officially, according to GM, it is an 'Allison branded 10-speed transmission'.
The 10-speed for the 1500 was a co-development between GM and Ford.
Wonder what country they were built in. I’m sure it’s cheaper for greedy GM to build it using their 3rd world child sweat shops than Allison to build their own.
Mine is shifting perfectly.
As for the off-road fuel, it has red dye to identify it. It is exactly the same fuel just has the red dye to identify off highway and the road taxes have not been paid.
Commercial vehicles can be fined for using it, but it perfectly fine for the engine.
The 10 spd in the 1500 has nothing in common with the 10 spd behind the Duramax
Edited by powerhaulic
'murica.
Same as previous generation. But it's in a different GM plant. (Flint now) toledo
Guess that makes the shipping cost less than before.
Edited by redwngr
Has anyone else felt that the truck with the ten speed coasts a lot easier? My 2016 LML with six speed would slow down much faster without brake. I now need to apply brake much more when approaching stopped traffic or stop sign. Not all bad just different than what I’m used to. Exhaust brake doesn’t seem to affect it either.
Yes I feel like it takes a little longer to slow down if the brakes aren't applied.  My 2016 almost always seemed like it was one gear too low while coasting.
Well that's a relief!
On 9/2/2019 at 12:03 PM, redwngr said:
'murica.
A1000 6sp was built in gm plant in Maryland.  10sp is being built in gm plant in Toledo, Ohio.
6 speed is built at the Baltimore plant
Thanks!
Are they building the 10 speed for the 1500 in Romulus?
Edited by redwngr
I believe what you are experiencing on the slow down is due to the 3.73 gears in the differential where as the 2020 is equipped with 3.42 gears.  Big difference.
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 461 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
