Finally got around to moving over my radar set up for my Redline EX & Valentine 1 from my Mustang. Behind the black cover is the Bluetooth module for when I want to run my V1. I just realized I didn't take any photos of the tap location but I will add that later.
What rear view mirror is that? Are those homelink buttons on the bottom?
It's camera rear view model in the Denali.
  • 1 month later...
Can you please show the tap locations for the power wire to the radar detector ?  Im fixing to do this and it would save me a ton of troubleshooting.
I love mine.  Shoot me a PM if you ever plan on getting Laser Defense.  I just installed an ALP system with 3 heads in the front and 3 in the back on my RST.
IMG_0109.JPG.d0a7340b12828860b91b299b5ad6075d.JPG.4f758a0ba48fc46c10bed15933f0a3d8 (1).jpg
IMG_0110.JPG.797019287ad672d2133c72190880df5a.JPG.e978e5af65f7d3e653adf3276f340c74.jpg
Saw a video and it said hook to the purple and white and the black and white. Now the rear view camera doesnt work . Any other ideas on where to get power that doesnt interfere with the camera ?
Last truck I was able to hard wire and tuck the wire into the headliner and run it down the A pillar.  The new truck the headliner is tight so tucking it in will require losing up the headliner some which may be a PIA.  Thinking about just putting the Escort on the drivers side upper corner to make it easier.
If you can post pics of where to wire into camera or somewhere up there would be helpful.   I've got the Denali with rear camera mirror and sunroof.
Sorry for the delay. I didn’t realize I had post notifications turned off for this.
Tap locations attached.
Facts it’s a PIA. I still need to hard wire this one. I  had the OBD2 port power module for the blackvue but it causes the camera to cut on and off for some reason in the GMC.
  • 5 months later...
Hey man I got bought RST also. How did you tap into rear mirror for 12v for your radar?
Look at the pics posted a few posts above yours.
Idk if it’s the same I have red, blue, green Blk and yellow
  • 5 months later...
I’m in the same boat... did you ever get an answer?
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
