Did it to me on the 395 heading towards Mammoth last weekend. Hats off to the guy in the Trail Boss that happened to be right behind me who recognized the noise and came over, said its happened to him 3 times in 15k miles. Started up again after about 4 minutes, but my confidence in taking this thing (with <4k miles) off the beaten path has just plummeted.
On 12/29/2020 at 1:58 PM, Steve-2019 said:
Read this and decide whether you want to do this or your dealer tech.  It's very easy IMO, but be careful.
I am very willing to give this a try, however i'll be pissed if the truck that I bought last month wasn't torqued to spec, if the issue had already been identified and "resolved."
Add me to the list. Happened Tuesday morning 400 miles from home at a hotel. Cranked over 3 different times for about 10 sec each. Got out to load luggage and back in and it started. Checked the fuse box bolts with the torque wrench at 40 in/lbs. All 4 were less than the 40. Tightened all to 53. Hope this solves any future issues. Called customer care and started a case to document what happened.
Edited by 2021rado
I had a crank, no start at 1250 miles. 2021 with LM2 built in March 2021.
Is the problem still loose bolts on the fuse box? I find it hard to believe GM has still not corrected this in manufacturing.
2021 Chevy 1500 3.0 Duramax. 4000 miles. Have had issues with truck randomly not starting, (cranks but won’t start). 4 times so far and every time was different, cold start, warm engine start......seems to want to start after 30 minutes or so.
Dealer is not aware of any other trucks having this issue.
Well Well Well. Looks like I'm not the only one GM has never seen this happen to before. On April 13, 2021 my 2021 Custom Trail Boss (5,000 miles) would not start. It sat for less than 18hrs from driving in the rain the previous day and had towed to the dealership. Next day they said they went to go look at it and she started right up. After looking at it for a week they could not find a single code or anything that could possibly be wrong. After so called going back and forth with GM engineers they supposedly looked at every connection and ground as well as do a hardware update. Well here it is May 4th and again it did not start as I was out the door at 0530 for work. Waited until the service department opened and talk to the girl who handled my file last time and said there is nothing she could do and GM does not have a repair at this time. All I can do is make the call to have it towed in and they will charge battery if needed. Damn thing will probably start by the time I get home. Why the hell do I have to worry if my $60k truck is gonna start?
Same thing on my new 2021 Sierra Elevation with the 3.0L duramax.  One time at about 500 miles, the next time at 4,000.  Both times I had my socket set with me.  I removed the battery cable for a few minutes and it started right up after that.  The last time at 4,000 miles I torqued the x50a fuse block down.  Seemed like they were way loose.  Now have about 6,000 miles on the truck and it hasn't happened again.
Edited by singlespeed
My truck is doing the same thing. My dealer said the same thing. It is pretty amazing we know this is an issue that is not uncommon with the vehicle but the dealers do not.
Dealer checked out my truck, said they could not get it to duplicate no start.....No kidding 🤷‍♂️. They also said the fuse box recall issue didn’t apply to this because my truck would actually crank, vehicles with bad fuse box wouldn’t crank. At least this is what he tells me.
Next time truck won’t start I am going to disable the auto stop switch as I’m thinking it has something to do with the alto stop feature.
Did you happen to ask them if the torque on the fuse box was up to spec?
Well add me to the growing list I guess, 2020 Z71 RST, only 3500 miles. We went to take to to dinner and it just cranked and cranked. It never started. Just shook my head and put the garage door down and jumped in my 2019 Honda Civic and went to dinner. On the way down to eat my truck texted my phone, said it needs service within one day. Got back in and tried it again and after cranking for a good 10 seconds it started and seems to run ok but thankfully a check engine light is on so it kicked something. It will go to the dealer on Monday. I will update here after I hear back.
I did not.....they said the fuse box issues didn’t apply to my concern. I will check the torque myself.
Possible fix!!!
My 2021 Sierra 1500 AT4 failed to start twice in the last month. Each time I waited several minutes and it eventually started. I just got back from the dealer and they found two codes in the history (P0300 and P12A6). They referenced service bulletin #20-NA-218 and reprogrammed the ECM.
supposedly this is the fix for the starting issues. I will update if it happens again.
Check service bulletin #20-NA-218
Anyone experience a permanent fix with this issue? My truck has the 3.0 duramax and I’m wondering if it’s potentially a different issue. Almost seems like the truck isn’t getting fuel while attempting to start. Always stars on the second attempt and never throws a code (which makes it real fun when dealing with technicians).
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
