Show me your running boards/nerf bars.
sixty4
Looking to add either Nerf bars or running boards on my 18 silverado reg cab, noththg jumping out for me. Show me what your using please, I really need ideas! Thanks....
I have the stock black plastic ones with a rounded-corner rectangular cross section. If you want your truck blacked out/chromeless, go with those.
If you want bling, get the same ones with chromed shells.
My first K2 truck didn't have them, and I leveled it. It was cool while I was a single guy, but get married and have kids... yeah. You're gonna need those steps.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Ive got the stock running boards but I want to change them to the retractable RBP power steps
I have Westin HDX step rails. No, they are not tubes or running boards. I like the looks of these better than those 2 designs, thought you'd like to see them.
Thanks, it is tough to find this configuration. Regular cab, 5.3 short bed and 4x4.. Since I've had it I've put on the DeeZee nerf bars, rear wheel tub liners, replaced the stock 17's with OEM GMC 20" wheels, catback Borla exhaust, rough country leveling kit weather tech in channel vent visers and front air deflector. Weathertech bed liner, AFE intake. Still need to put Bilstein's on
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
