1 hour ago, Smoothbassman said:
I need these switches in my life!!!
Sent from my SM-N960U1 using Tapatalk
Yea they are really nice. Tied my interior footwell lights into one of them, have some strobe lights tied into another and working on a front light bar for aux 3. Nice to have lots of switches for future equipment! Here’s One of the threads where they are discussed. Let me know if you need any other info. https://www.gm-trucks.com/forums/topic/228976-anyone-get-the-9l7-upfitter-aux-switches/page/4/?tab=comments#comment-2393894
On 3/22/2020 at 7:06 AM, maillet282 said:
I wanted to do something a bit different.
installed one of these Switchpods. Still waiting on 6 AWG ring terminals to arrive in the mail to finish wiring up the relay pod itself
Really digging this set up rather than cutting into the dash panel.
Needed to drill 4 small holes as well as remove the cap off the USB and the 110v plug. Same with removed the 2 12v plugs as well
but the panel only costs $30 Canadian if I want to return to stock
I found a great reference for possibly adding switch functions where you'd like to (under the radio in the center stack). Let me know if this helps:
https://www.findlayautoparts.com/v-2020-chevrolet-silverado-1500--rst--5-3l-v8-gas/body--switches
I want to add the RC 10" mini LED's in my grille, and possibly a dual mode exhaust (more on that if it progresses) and I too want a factory look (no weird/non OE looking hardware) so I think this may be where I start to look.
I installed rocker switches. I prefer bigger ones with labels that are easily identifiable vs numbers, since the location is partially obstructed by the steering wheel.
Did those come with any kind of wiring harness or did you have to make something up yourself?
Currently I only have a light bar hooked up. It came with the wiring harness and a switch, but I didn't like the switch. These are on Amazon, They were around $8-$9 apiece. The two switches on the right aren't snapped in completely, so they'll be easy to pull out to wire up when I get the other lights (rear and A-pillar or fog..not sure yet).
  • 6 months later...
Do you know how to hook lights up to these buttons? I can’t find out how to hook them up.... TIA
I went with a Spod bantam
Jesus. You could’ve gone for a feniex mini 4200 for a whole lot less but go ahead and get your flex on!
Haha the feniex mini is cool but I liked the design of the bantam with the under hood connection box
On 3/21/2020 at 10:43 PM, 2k19Sierra said:
The gm aux switches are on the left side of the steering wheel now. Couple threads on here about them! They work great!
Two options I wanted in my truck but did not because of limited availability was upfitter switches, and trailer TPS.   Does anyone know if the harness and/or relays for this is already in the trucks?  Could the switches be purchased and installed as a 'plug n play' solution?
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
