I am curious if it's possible to increase the USB to the 2.1 amps instead of 1 amp? My phone while using navigation will drain faster than it can charge so I was wondering if it's possible to upgrade it?
Sent from my Pixel 2 XL using Tapatalk
Of course. I put a QC 3.0 panel in a truck jump seat I put between the captians in my burb. All you need is a single socket. 2 wires...23d7934f4339a13f5cd282da7e8ae3ee.jpg
Sent from my SM-G975U using Tapatalk
1 hour ago, Texas Daddy said:
Of course. I put a QC 3.0 panel in a truck jump seat I put between the captians in my burb. All you need is a single socket. 2 wires...r
That's not upgrading the USB port.  Doing that prevents you from using Android Auto (or CarPlay forr the Apple Sheet), so a very certain no-go.
Fortunately, my LG G7 ThinQ, even with Waze, streaming spotify, Android Auto and a Hotspot going can do it without the battery draining further, but it doesn't charge much.
You can wireless charge and cable charge at the same time. I do this occasionally if I want my phone to charge faster.
May I suggest something may be wrong with your phone. I use navigation and I heart together when I travel my phone charges. That’s through several different automobiles. That’s an I phone tho, that could be the difference? I never heard of this, the only reason I bring it up. I did have a phone get stubborn about taking a charge be before I up graded.
If your phone is taking a long time to charge, it's ready to be replaced.
Sent from my SM-J810F using Tapatalk
You could replace the battery I’ve done that.
My first thought is the phone is the problem, not the truck.  Even if your phone is new, don't rule out the battery.
I've now gotten in the habit of always charging my phone on low power mode as it charges quicker.
However, the USB ports don't charge as quickly as using a regular car charger I have noticed but I've never had the phone die quicker than it charges. I usually don't use the USB ports because they will turn off after all the computers in the truck go to sleep, and when changing a song on my playlist there is enough of a delay when the phone is plugged up it annoys me. Wish that could be changed. But that's off topic... ?
My phone battery stays constant while charging with navigation going, and screen off.  I bought one of those 12v cigarette plugs with a 1amp and 3amp outlet, this did nothing to help.
did you try a different cable? maybe your cable is faulty.
you didn't mention what type of phone you have, what plug does it have? if type-c or lightning, try flipping the plug, sometimes it'll kick it to a faster charge cycle.
i too would like to know if there is a way to upgrade the factory usb ports to a higher amp# w/o loosing factory options?
They are built on the USB 2.0 standards and they are probably only operating on 0.5A. The manual says that they are not for charging but for data transfer from HDD, flash drives, and the like. While 0.5A is pretty anemic, it is enough to run an HDD or a flash drive. I cannot find anywhere what charging standard they are operating under, if it is 1.2 then the USB should be rated for 1.5A.
What radio RPO code does your truck have?
I had that problem with my pixel 3 in my truck and charger. I changed my USB cord to one that's compatible with quick charge and haven't had a problem since.
I also keep a charger available that uses the 12v plug.  This will allow me to charge when the truck is off and you can buy one with a higher amp rating.  I seldom leave the house without a fully charged phone so I don't need to fuss with the phone when driving.   Law enforcement here is pretty strict with the use/placement of phones and I keep my phone out of sight to avoid any issues.
    daveishi
    daveishi
  • Who's Online   4 Members, 0 Anonymous, 1,079 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
