Just like the topic says. Like to see how some higher mileage t1's are doing. I know there is a topic for high mileage 2019's but I would like to extend that to 2020's.
My 2020  AT4 only has 1500 miles, coming from a 2009 (relatively) trouble free 160,000 mile Tacoma (which I purchased new) I am real curious how the T1's hold up.
almost at 12k
3 dealership visits for my engine knocking noise. about 4 weeks total out of service.. still knocks. sounds like its going blow up on cold start.
1 dealer visit to have the frame coating redone because the frame already had rust spots after 900 miles
1 dealer visit for flashing check engine light. 1 week out of service.
Going back in tomorrow because my brakes randomly didn't work last night backing out of a parking spot at the grocery store.
Edited by ct_corey
spelling
  • Sad 1
Saw one on Autotrader with 45,000 on it. I think that's the highest mile T1 I've come across. Mine is at 7k.
Mine has 14K miles but outside of having my passenger mirror replaced twice I haven’t had any issues. I don’t understand my front brakes at 14%... It’s been stuck on 14% since 12K miles... I mentioned to my service advisor when I had my truck serviced at 12K miles and he said it wasn’t an issue. Meaning my brakes were fine... Still doesn’t make sense how low it is reading but I can ignore that for now...
There’s a TSB for this. Find a better service advisor.
Glad people are chiming on with no problems as well as people that have issues. My FIL said every GMC he had, all his issues/problems came in the first 10,000 miles and trouble free after that....
2019 TB LT. 25k and only issue was the oil cooler line at 22k. Dealer extended the warranty on the engine and no further issues. Build date of 12/15/19 and picked up 1/12/19.
13K and my old issue is the old lady that missed her brake pedal coming in behind me at a traffic light and crushed my bumper and beside... probably saved her from getting seriously t-boned though.
Did the motor get starved of oil while you were driving?
I do not think so, I got off the road immediately but I figure better safe than sorry and the dealer was willing to submit the claim to GM (after multiple follow up calls). I plan to keep the truck for 5-7 years so it was important to me.
Did you mean build 12/15/18?
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,247 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
