Has anyone purchased and installed this keypad?  Wondering if it works if the key fob is left in vehicle to keep the truck running instead of turning off after the predetermined set time.
Curious about this.
I leave my truck running often in the hot summer or cold winter as I bring my dog with me everywhere and he stays in my truck when I do site visits. I hate how the truck turns itself off.
Interested myself. I can't find any info on this online other than a GM-authority article. Does anyone know if this is wireless and just sticks on or how its installed?
Edited by bharris515
I was keeping an eye on this device as well. This is copied from shopchevyparts.com
Designed for mounting above the door handle on the driver side, this keyless keypad can be placed on any blemish-free glass or painted surface on the vehicle. Forget the magnetic "hide-a-key" and use this Remote Keyless Keypad to unlock the doors securely.  Think digital "hide-a-key".
I have this.  I know you can lock the fob inside the truck with it, which is what I wanted.
Not sure about keeping the truck running and wasn't even aware that the truck would shut itself off after some time.  I never let mine just idle for any amount of time.
It is a neat little device.  Dealer had to program it to the truck, then yes it just double-stick tapes wherever you want it on the truck.  It does seem a bit cheap and fragile so I do wonder about how long it will last, but so far so good.
first person i have heard with this on . got a pic? i like my ford work car with that on it - never take keys out
Hmm now I wonder if it would survive the automatic car wash over time...
Wonder if you could stick it to the inside of the gas filler door? Then you run the risk of the gas fumes messing it up or the double stick tape. ?
I can snap a pic, but like Steve mentions, I have yet to mount it due to concerns about how it will hold up to the Ohio Winter.  I did consider inside the gas door, and that may / may not work as it looked to be a really tight fit.  My thought was to mount it in the area where the mirrors are mounted on the older trucks - keeps it hidden as I think it sticks out too much if you mount it on the B pillar.  I had a $100 accessories credit, so it only cost me $100 including dealer programming.  In hindsight, just not sure it was worth it as it looks to be disposable after 18 months - maybe I am wrong, but it just does not exude quality or resilience in my opinion!
Thanks for the input. I think on the door where the previous mirrors mounted would be the safest place. I'd be curious if you can install it and then run a bead of clear silicone sealant around the outside end of it to seal it to the door panel?
Can you actually lock the key inside? im scared that it might think the key is "near the door" and will unlock if someone tries the button.
Where do you put the key?
Yes, you can lock the fob inside.
Agree, I checked tonight and you can lock the fob inside. The GM pic shows the front well, so I snapped a pic of the back for you.
I just ordered one of these. I’ve always thought that was a good idea when I’d see my friends with Fords use them.
Are they backlit?
Are they backlit?
was wondering same thing. Is it backlit? Also are they physical buttons you press or like a touch screen?
Yes, it is minimally backlit once you press a button.  There are five actual buttons - one in the section marked 1/2, one in the 3/4 section, etc.
You can lock the truck without putting your code in.  Inputting the code unlocks the driver door, you can press an additional button for it to unlock the other doors.  If you hold the buttons, it will fold/unfold the mirrors just like the fob does.
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
