Figure for everyone wondering what your intake valves will look like after 78k miles with no catch can, full synthetic oil changes every 5k and only premium fuel used.. see below. Motor was torn down for AFM lifter failure.
Interesting.  I was kicking myself the other day for not having them take pictures of my intake valves when they did my AFM lifter replacement a couple months ago.  I'm pretty sure it's the cause of my (very slowly)  increasingly rough idle.
Same with my idle. I wish they had sent me a pic upon tear down so I could have had the heads sent somewhere to be walnut blasted before it was put back together.
Got to love DI.  I wonder if a regular treatment of the spray can CRC valve cleaner make any difference or would that happen eventually anyways?  That's pretty nasty looking for only 78K miles.
Ummm that doesn’t look bad at all
its black and nasty looking but as far as Actual buildup not that bad
Edited by truckguy82
Wow, that looks pretty bad. Only 78k miles? I've seen some other pictures on here and they look bad too.
I do 5,00 mile oil changes too...and run a catch can. When I reach 70k miles I'm planning on pulling the intake off and doing a manual cleaning...wondering how it'll look (not sure how much help the catch can is actually giving).
Was thinking the same, not great but not awful.  Doubt that is causing any issues at all.
uless your loosing MPG's i wouldn't bother tearing the manifold off, your better off finding a private BMW shop that does walnut blasting and let them clean it correctly. or you guys can buy the vacuum blasting tool online, and get a 50lb bag of crushed walnuuts. and blow the weekend cleaning the valves.
+1
Not great but I've seen a lot worse. Either way, while you have the opportunity get it cleaned up JL!
Obviously, pulling port fuel injected heads would most likely reveal something that looked brand new with a few specs.  This is most likely gonna happen regardless and unfortunately quicker on GDI's and has nothing to do with OCI intervals at all.  Is it bad?  It's not great but it's not gonna do anything for your ownership life expectancy.  We all be coking.....................
That isn't bad if you ask me.  This is what I would call bad, picture of BMW valves. Before and after cleaning.
2 hours ago, Jacoby said:
Those look horrible
Carbon buildup from di has been known to cut out like 25-30% of hp
while it looks bad compared to port injection, it looks fantastic for di. Probably losing like 5-10hp tops.
his is the worst ive seen for the lt motors, and its really not that bad
could also just install  hydro boost from a 2500 in place of the vac pump,  delete vac pump lines, and run breather filters on your valve covers.. problem would stop there..
Edited by flyingfool
Nasty. Now we know why Ford used their noodles and did DI + Port Injection. First time I thought I would ever give Ford credit over GM in the engine/powertrain department but in this instance they won and GM looks like the dummy. Trade them in before warranty is out. Motto of new vehicles beyond the year 2001.
    • Get the 5.3. I`m not a Ford guy.😉   I think these L84`s are less problematic than the L83`s. Certainly less than the L87.
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
