I remember in the 2000's trucks were shipped with synthetic fluid in the front or back but not in the other (can't remember which order). I believe it was 75w90. Is that still the case today? Just wondering as there is a lot of rolling resistance when extremely cold
It use to be synthetic in the back and not in the front but now in the new trucks it is synthetic in both.  If you need to look up what yours takes you can do that on this look-up guide.
75w-90 Severe Gear is what I put in both of mine on my 2002 Silverado.  The new squeeze packs make it a breeze and no mess.
I believe the last year they included info in the OM was 2018.
Different weights, but diffs always synthetic.
Transfer case uses Dex VI ATF
Front Axle – Four-Wheel Drive SAE 75W-90 Synthetic Axle Lubricant (GM Part No. 88900401, in Canada 89021678).
Rear Axle (1500 Series) SAE 75W-85 Synthetic Axle Lubricant (GM Part No. 19300457, in Canada 19300458).
Rear Axle (2500/3500 Series) SAE 75W-90 Synthetic Axle Lubricant (GM Part No. 88900401, in Canada 89021678).
Transfer Case (Four-Wheel Drive) DEXRON-VI Automatic Transmission Fluid.
Just as a quick heads up, these new 1500's have 2 different axle manufacturers and call for two different GM fluids.  75w85 is the weight now though.  See the link to the stickied quick reference guide below:
Do you know the capacity for the diff fluid on the 1500? I checked amsoil website but I don’t know which code I have
I know this post is quite old but how do you tell which rear axle supplier your truck has? My BIL has a 2020 1500 w/ 5.3 that needs some fluids changed and I have a 2022 1500 w/ LM2 that will need the fluid changed once I am through it's break-in.
I have a 2021 Sierra LM2 and had to give my dealer the vin to get the right rear Diff fluid. There are 2 diffs. I still dont know which one I have...but I got the right fluid.
You would know by looking up your RPO. 😉
I'm waiting to get the RPO build sheet from my dealer since GM apparently can no longer give that information out via Chat. I was hoping there was another way I could tell without RPO codes.
I tried scanning the QR code on the door jam tag to get my RPO codes but that didn't seem to work since it didn't display all of them. Not sure why GM decided to stop putting the RPO codes on the sticker.
Edited by Mossyoakglock
You have a different truck than the 2008 in avatar and In signature?
2008 would have  label in glovebox with rpo's.
If it's a (different and new enough truck enough it will have a QR code on doorpost.
Has a bunch of the rpo codes that impact service/service parts. (not as many as glovebox label)
May include the axle info.
Any dealer can print the build sheet from a vin number.
Yea, picked up my 2022.5 Silverado 1500 Z71 w/ LM2 that I ordered at the end of August. I tried to change it the other day but every time I tried to save it, it said the page didn't exist.
I scanned the QR code on the door jam but I think it's missing some RPO codes. When I scanned it, no codes with an S showed up. Will the dealer report have more codes than what the QR code has?
Yes, a lot more!
  • 4 months later...
Im going to take a HUGE chance and run the same thing in both axles.....🙄
What mentally deficient group of designers at GM thought it would be cool to make them that close, BUT different!? Unbelievable.
Edited by Minnvmax
Living on the edge there! lol
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 246 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
