Wheatland Yellow....have yet to see one on the road but IMO not my cup of tea and resembles to much like the municipality work vehicles
I am trying to get my dealer to let me order a yellow trail boss LT.
Has anyone gone through the fleet order process?
Thanks,
Chris
Why does your dealer have to let you order a yellow one? You're the customer. If he doesn't want to order one for you find another dealer.
The dealer is probably afraid the he won’t pick it up and then they will be stuck with an unsellable color. Unless DHL needs a Trail Boss delivery truck.
I don’t think there’s any minimum order for them, but they won’t build until they have 5 orders for that color at the plant. And either way, I don’t think GM intends for people off the street to be ordering these colors, nor do they make it easy.
  • Haha 2
I love crazy colors on cars. Dodge is really the only company putting out fun colors.  I actually like the yellow. GMC had a nice dark orange a few years back I would have loved to have been available for 2020.
2 hours ago, lapoolboy said:
That is atrocious.
HAHAHA. The yellow could be ok if the exterior was modified with aftermarket parts
Yeah I liked that burnt orange too
Well I like the yellow myself. I also considered orange.
The salesman I am dealing with was supposed to find out the process, since he had never ordered a fleet optioned one before.
I like having the ability to spot my truck in a crowded parking lot :D
I wish the sea foam green or light blue was still an available option for the trucks, but a yellow trail boss LT with the rst rally stripes is sounding pretty good to me.
Thanks,
Chris
Winner!!!
