I have a 2016 gmc sierra 1500 having a issue everytime I hit a turning signal my radio/display screen turns green then come back, also my back up camera quit working any help would be great
Welcome to the site.
First 3 things could be, your HMI module is going bad, you have a bad battery, or a bad ground somewhere on the truck.
  • 3 years later...
Did you ever figure out what this problem was you were having?   My truck is doing the exact same thing.  Every time I put blinker on screen goes to green, and back up camera is not working.   Also screen blinks right around 12-15mph every time you start or come to a stop.   This is the only other post I've seen with this problem.
Edited by Patiobob
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
