7 hours ago, DenaliDave said:
I remember seeing a post in the forums where the chrome strip was removed. Believe it was heated with a heat gun and “peeled” off. Not sure if I’d recommend that.
I'd be interested to know what the surface is underneath, but I would not be willing to be the one to test it out
On 9/11/2020 at 8:35 PM, sharkeysierra said:
It’s just plastic for the grill/fog/mirror/door handles.
Yeah those parts I already knew and took care of, what we were discussing was the power running boards which I expect are not simply plastic beneath the chrome, or at least as flimsy as the parts you listed.
 Ah, my assumption was the plastic after the heat gun comment.
Running boards/bumpers are steel.. sandblasting would take care of it. Although, a good 60/80 grit scuff and epoxy primer will be sufficient.
Door molding around the windows are aluminum, Same as above.
I finally found the topic where the chrome strip was removed from the factory powered step/running board.  Doesn't look too bad.  See link below.
LINK HERE
Edited by DenaliDave
Added photo.
LINK HERE
That makes complete sense.  Simple to do which is good to know.  Right now I  like having mine wrapped, but not sure what I will do down the road
  • 10 months later...
On 5/17/2020 at 7:53 PM, wizard4878 said:
all you chrome and stainless haters out there can send all that good shiney stuff to me!
I’d love to trade if you’ve got black window trim and/or door handles. 2021 Sierra SLT
sorry,  I do not,  all chrome here
  • 4 weeks later...
On 8/4/2020 at 2:06 AM, Jeffrey Soulages said:
Did you notice when you were installing your grill if the outside trim was able to separate? I am thinking of buying the same grill for my AT4, but only want the insert. I'd like to re-attach it to the original trim piece as it is the body color (white).
Thanks
J
Not sure if you ever got an answer, but yes, you can remove the grille surround. I did it. I got an sle grille already paint matched and swapped the outer trim. It’s about a dozen tabs you have to carefully pry apart. Once you get a couple released it’ll go. Got rid of my chrome grille surround and color matched it. Left the Denali center chrome. Looks way better.
Edited by DarkSky20
Misspelled autocorrect words
  • 1 year later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
