stall
13 minutes ago, davester said:
Replace the passenger side katzenframmer,
I think for the model he did not bother to provide, it is usually the drivers side that goes bad....
DUDE, GIVE US INFO.
motor stalls. We have no idea what is happening . please let us know what year, make, model, engine, trans?
What leads up to it stalling?
Does it completely die or does it starve for fuel? does it lunge?
1 hour ago, stephen brawner said:
engine stalls then won't start until it sits awhile
Year?  Make?  Model?  Engine?  Any codes?
I had that problem on an old truck once. It would run great for about 5 miles. It would shut off after while it would start like nothing was wrong and go about 5 miles. It was a toy so for about two months I replaced everything. Later I found the gas tank was full of crud. The crud would clog the sock and no fuel would flow. I had stuck a hose in the tank to drain out gas for the lawnmower. Knocked a bunch of crud loose. To lazy to run to get gas. Cleaned the tank problem shoved.
Gotta love these topics that are so detailed
Sounds like all the signs of a muffler bearing going bad or your drive shaft fluid level is expired
