Does anyone know when Chevrolet stopped making the 8FT Bed for the Quad Cab model on the 1500 trucks?  I know they still have them for the Single Cab, and on the 2500HDs Crew & Quad Cabs, but just curious any insights on why they don't offer them for the 1500 Quad Cab.  I see very many 1990s early 2000s Quad Cab 1500 series trucks with the 8FT Bed, and under the belief they were popular or at least that some healthy demand exists.  It would be my first choice if they had them....
Found this post on the site from 2012.
Silverado 1500 Extended Cab Long Bed
I believe the NNBS body style is when it stopped, so 2012-2013.
I still see a few around sometimes, kinda goofy looking when there is an 8 foot bed on a extended cab 1500.
Quad Cab? What is the this the Ram boards ? You can get killed with that lingo around here. Just kidding ?? In all seriousness my thinking is sales.
  • Haha 1
11 minutes ago, Doolin-Dalton said:
Hmmm...link don't work
Sorry, looks like it is a closed post. Just copy and paste the link and it will pop up in an internet search.
GMT-900 was the end of that road and I’m always shocked when I see one in person. Extremely rare, not a good seller.
And I agree, somewhat goofy looking. The HD wears that look a lot better if you can find a place to park.
Just not where the market is anymore.
On 8/8/2020 at 6:52 PM, JimCost2014 said:
Here is a 2012.
See the source image
Yeah, I like em, alot.  Just seems more proportional to my eye.   My 2500HD had an 8FT Bed, and I kinda got used to it.  When I purchased this new 2019 TB, I was surprised to learn it wasn't even an option anymore.
i guess they dont sell them but i personally know quite a few who would like dbl cab 8ft 1500.....they need the space but not necessarily payload of 2500....
The long beds are too hard to drive ?  People live in cities and they don't like the 5% more effort it takes.  Even on the 2500s 8ft beds are rare to see here in Orlando area.  Probably why I'll be getting another dually when it's time to get a new truck, 8ft bed is the only option with a dually from GM ?  GM produces what they think people want or what they can sucker people into buying.  There aren't enough of us that want 8ft beds anymore for our opinions/wants to be financially relevant to them.
Long beds are for working guys.
Here is my 07 LTZ 8 ft bed. 2" level and 2" lift in rear. Bought it new on Christmas Eve 2007. Leftover nobody wanted. I stole it for $27,000. $13,500 off sticker. That was unheard of back then.
I hauled my tools around in that one for 5 years. That was one of the best trucks out of the sixteen Chevy's I've owned.5ed5f2eab761baa81f55fb359d581111.jpgd137de7412babfdfd4dffa0dc5a70384.jpg
Sent from my Pixel 3 using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
