newdude Posted September 10, 2020 Posted September 10, 2020 (edited) 41 minutes ago, ChevyMyers said: 2nd update** Although the tail lights are now working correctly, I’ve lost the bed cargo, which alludes to that god awful connection is needed so I will have to pull the cargo light off...... Any ideas how to remove it with out breaking the damn light??????? ive tried the pry method and I swear it will break in half lol Pop the lamp out. Take a plastic trim tool and slide it up under the bottom of the cargo lamp to release pressure on the retainer on the lamp. Then you will be able to unlock the red tab and then push the tab right under the red lock to release the connector. Edited September 10, 2020 by newdude
kioolt Posted September 10, 2020 Posted September 10, 2020 The cargo lights should be removed by prying at the bottom only. Do not pry the sides or the top.
ChevyMyers Posted September 10, 2020 Author Posted September 10, 2020 1 minute ago, kioolt said: The cargo lights should be removed by prying at the bottom only. Do not pry the sides or the top. Oh wow good to know, I’ll try again after work, thanks buddy!!!!!
ChevyMyers Posted September 10, 2020 Author Posted September 10, 2020 31 minutes ago, newdude said: Pop the lamp out. Take a plastic trim tool and slide it up under the bottom of the cargo lamp to release pressure on the retainer on the lamp. Then you will be able to unlock the red tab and then push the tab right under the red lock to release the connector. Thank you!!!! I’ll try this
amxguy1970 Posted September 10, 2020 Posted September 10, 2020 (edited) What do you have planned for your "build"? So far a bolt on lift kit and wheels, are there some build plans coming with some fabrication and working together of parts? Speaking of wheels, I don't think I have ever seen wheels with such a misnomer name, those are about as far from "hard-core off-road" as you can get with out a Bugatti emblem on them. Like having a maltese named killer... Tyler Edited September 10, 2020 by amxguy1970
ChevyMyers Posted September 10, 2020 Author Posted September 10, 2020 GOT IT!!! lol I was able to remove the cargo light with a skinnier pry tool, as suggested I went from the bottom only and lifted up, and it finally popped out! thank you everyone who replied, y’all are awesome!
