(2019 Silverado 1500 LTZ) It is intermittent but as soon as I plug my phone into the truck via USB-C cable and connect to CarPlay, eventually during my drive when I try to adjust my volume it is super delayed to register the volume change. After a couple minutes the entire dash goes black and restarts. Almost like the infotainment system freezes. No idea what could be causing this and there isn’t anything out there regarding my issue. Any ideas?
Edited by Mcar33
2 hours ago, silveradosid said:
have you tried a different cable or another phone to see if it still does it
Yes, newest iPhone and new Apple cable
Do you have your phone also paired to the radio with Bluetooth? I had this problem with my truck, 2020 Trail Boss Custom. I had paired my phone with my truck with Bluetooth and connect the cable to it as well to charge my phone. That’s when my radio would freeze or restart randomly. I ended up deleting the Bluetooth connection and just ran with the wired connection. I haven’t had a problem since. That was my experience with the issue.
  • 3 weeks later...
ragdoll hit
That’s really interesting! I’ve been having a similar issue with my radio randomly freezing, and I never thought about the Bluetooth connection being the culprit. I usually keep my phone connected via both Bluetooth and a cable for charging, so I might try deleting the Bluetooth pairing and see if that fixes it. Thanks for sharing your experience—hopefully, this works for me too!
Hopefully it does the trick. The best guess that I can think of is that both the Bluetooth and wired CarPlay fight for the priority connection for the iPhone and that’s what throws the radio into its random freezes.
  • 2 months later...
I don't have an iPhone, but saw a story yesterday that apple has released and update to CarPlay.
Might be worth checking out.
Don't know if it impacts the connectivity issues, but it did mention that on some vehicles it would make more apps available on the screen.
Edited by redwngr
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
