Just got a ‘21 RST ccsb satin steel 6.2.  Leather buckets.  I miss some of the things my 18 LTZ 6.2 had but I like some of the new features this truck has.  I put Hankook Dynapro AT-2 275/60-20s, I don’t like how narrow the Goodyear Trailrunners look. Truck has the black emblem package, and I have black Z71 fender badges on order.  I’m contemplating the accessory black grill, probably gonna do the muffler delete (it’s quieter than a 5.3 truck side by side), and contemplating level/lift.  Probably gonna start with just a 1.5” in the front.  It’s only $37.  If that’s not enough I’ll go 2” in the front and either 1” or 1.5” in the rear and nothing more as far as lift goes.
19 minutes ago, fsuboy75 said:
Can't wait to see the pics and progress!!!
Gotta feeling it’s gonna look a lot like yours.
I wouldn't put the black grille. It just looks too much like a WT, commercial fleet, or a utility truck . Looks cheap and rattle can looking. My opinion.
  • Confused 1
I thought my previous Redline edition truck would look cheap/work truck ish with its black grill and door handles, but actually looked pretty good.  Probably because the black was gloss instead rough unpainted plastic. But I know how you like your chrome. I actually do to, but not on the new trucks.
Edited by SILVER SLED
31 minutes ago, Rod M said:
I ordered one 6 weeks ago how long did it did it take you to get yours
This truck was actually ordered months ago.  I kinda suggested a truck like this to order, because I would like it, while maintaining I was gonna buy my 18 6.2 LTZ  Redline when the lease was up.  Well I took this truck home for the night and drove them back to back.  The rest is now history.
Lol yep. I like chrome first then color keyed. Black my least favorite.  But it's whatever one likes; it's all good ?.  Gongrats on the new truck! Post pics.
Congrats! Definitely go with the muffler delete on the 6.2. I did on mine and it's great. At $75, it sounds just as good as those $1400 systems to me for much less money. Post pics!
My last new Texas editions truck was color matched. Door handles and mirrors. I had a Ford even had color match rim inserts and grill. Along with mirrors and door handles. I’m not a fan of lots of bright.
Agreed.  I have a hard time spending that much on an exhaust on an otherwise stock vehicle just for sound.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
