Maybe until it's unlocked but a full dyno tune around here (Chicagoland) is around that price.  I've had things like tire size, O2 delete, or speed limiters flashed for the cost of a couple cases of beer.
hey I’m really interested to get these mods done in my 2020 LT and I’m in Chicagoland would you recommend the right place where I can get this done please?
Very few have 'cracked the code" on these, I doubt anyone is doing it on a 2020 6.2 for a couple cases of beer.
You need $1400 for the ECU and then credits and THEN  a tune, LMR figured them out but it took him a long time and they are one of the best in the business.
You will void any warranty by swapping the ECU as well.
My Pulsar will be here in a few days less than 6k miles on truck I will do ALL mods possible without killing the warranty.
Review and install vid to follow.
Cheers
Just to be clear, the price is NOT a case of beer etc right now.  I was referring to my old vehicles (eg 2000 Trans Am) where pricing wasn't bad because the ECM was unlocked.  There is ONE company that can handle this, HP Tuners.  They are based out of Buffalo Grove IL
https://www.hptuners.com/
It's going to cost you over a grand to unlock the ECM.  Then, you will need to pick a speed shop to do your tuning.  I have used Speed Inc (https://www.speedinc.com/) for my tuning in the past but not sure how good they are with these new rigs
Edited by Rob Mugs
thats for sure I was thinking couple of hundred bucks haha, thanks for all the info actually i was into Pulsar too but it was out of stock everywhere, after your last post I started to search again luckily it was showing available/in stock today, so placed an order and after an hour got shipment confirmation too, woohoo, Pulsar LT sounds like an easy way to go, Thanks for the heads up [emoji16]
11 hours ago, navaidone said:
thats for sure I was thinking couple of hundred bucks haha, thanks for all the info actually i was into Pulsar too but it was out of stock everywhere, after your last post I started to search again luckily it was showing available/in stock today, so placed an order and after an hour got shipment confirmation too, woohoo, Pulsar LT sounds like an easy way to go, Thanks for the heads up emoji16.png
Where'd you order from?
I ordered mine from Edge.  It showed backordered but I went ahead and did it.  They instantly charged my card (late February) and showed mid April as expected shipment date.  It came 2 weeks ago.  Can’t complain too much.
Thanks, but I was asking @navaidone since he ordered one very recently.
Thanks, but I was asking@navaidone since he ordered one very recently.
i ordered from mbenzgram.com on friday morning, it was showing back in stock, and later friday got an email for shipment confirmation, they have 10% promo going on so I paid $413 (no tax) lol
i bought few stuff in the past never had problems with them.
The Pulsar seems to be a piggyback system and very limited.  I'm waiting for WAMS to come back in stock.  Tons more can be done
You are welcome.  You really didn’t even need to reply if it didn’t matter.  I thought you might have been looking for one and needed a source.  I was just attempting to be helpful.  I’ll make a mental note moving forward.
  • Haha 1
Sorry your feelings got hurt.
For someone seeking info you sure are trying hard to prevent it from being given to you LOL
  • Haha 1
My God guys!  There's a reason why I quoted @navaidone in my question.  I was interested in where HE ordered from because he did so very recently.  I said thanks to @Wakinvol for his answer but clarified I was asking someone else who had ordered more recently.  Give me ya'lls mailing addresses and I'll send some coloring books for your safe space.
  • Haha 1
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
