1 hour ago, burgie189 said:
Is anyone using it on a 2021?
I took the slight gamble and tried it.  It works just fine on my ‘21.
Cool, ordered one yesterday.
Like to see if there are any updates from the guys with the 6.2....hate for my truck to stall out with it being a non installation issue
I agree with you. I’m hoping the bugs have been worked out of it and I’ll order one here in the spring when this crappy weather leaves Iowa.
On 1/18/2021 at 7:31 PM, Vmax08 said:
Got mine today for the 6.2!
Install went smoothly. Turned off auto stop & DFM.
Hopefully there won't be any problems....
What's your verdict after two weeks of running this thing?
So far no problems & very happy with it. I got it to turn off DFM & auto stop. Works perfect!
I set the throttle response to LEVEL 2. Manual says this is 15% over stock and I can feel the difference in throttle response.  I haven't set it any higher just because I am happy with the current setup. I see Firehawk T/A mentioned something when used with cruise control but I haven't used it with cruse yet.
Mine has been on about two months.  No problems or issues.
1 month...no problems on my 6.2L.  DFM disabled (auto stop disabled by default), tire size corrected for 37s, no TPS increase and it holds a gear going up hill unless I get off the gas.
Do you have the link to the one you ordered?
Is this just the 89.99 dollar Range Pulsar?
When I ordered mine through range, Jan 4 this year...i did recieve an email saying it was on backorder...still got it in two weeks though.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 623 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
