Installed mine today. I ran into one thing where option 6 (60 mph) was not the auto start disable but was throttle response adjustment. I can tell you when you set it to the highest setting acceleration is extremely abrupt. I'm waiting for my usb to odbii cable then I'll update it to see if the options change. So far very happy with this!!!
Let us know if there is an update. I was told there wasn’t as they were new and “shouldn’t need one”.
Will do. If there isn't I wonder why option 6 was acceleration and not stop/start. Has anyone else seen this?
Anyone with the Pulsar LT using this with a CAI? Watching the Pulsar installation video the unit is attached to the top of the air cleaner box with velcro strips. Wondering where you are attaching the Pulsar unit if you are running a CAI? I have the Roto-fab intake and didn't like the idea of attaching the Puisar to the clear lid.
You can mount it wherever you want.
Question for those who have  the Pulsar. Once you have everything set where you want it does it have to be reset if you remove it and then reinstall it? Example being you are bringing vehicle to dealership for oil change and do not want it recorded that Pulsar is in vehicle. You take it out, have service performed, then reinstall it.
I'm researching this myself. My initial thought is that it would reset itself but I'm not sure.
I have the Pulsar LT on my 6.2 AT4. I imagine you would have to adjust it to your preferences once its re-installed. But it probably took me all of 10 minutes to figure out how to adjust what I wanted and actually change it. It's not time consuming at all.
I disconnected mine when I was having the lane change alert issue. It was only disconnected a couple minutes, but it held it's settings.
Are you saying the device held it's settings/memory when unplugged and then plugged back in, or are you saying the truck held the settings when the device was unplugged?
The device held its settings.  The truck never actually "changes" any programming.  The Pulsar intercepts the signal and modifies it.  Its a piggyback.
-Eli
I had a few days of no problems then...
I was driving from Minneapolis to Kansas City today. My truck started throwing up tons of error codes and wouldn't restart after turning it off. It wouldn't even crank.
I unplugged the Pulsar and took it out of the system, everything fired up.
I am going to ship it back, not sure it is fully developed yet.
Tom
Tom
Wow! Thats not good. I think we got ours about the same time. I installed mine on Black Friday. So far so good, although I havent driving it more than a couple hundred miles yet. Did they give you any problems with getting a refund?
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 540 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
