These issues are unfortunate I was about to purchase this. Guess I'll wait to see if they update it.
They have a 30 day guarantee. Maybe you’ll have better luck than me.
1 hour ago, Jav_eee said:
Mine worked fine all weekend after the small problem I had when using it “on the fly” and finding out they don’t really mean that. Remote started it today and had a CEL. Onstar couldn’t give me the code, “unable to probe module”. She asked if I had anything connected to the truck. It wasn’t shifting right and surging at cruising speed (35mph).
I’m really hoping my device needs an update but the tech support person I spoke with this morning said “probably not, it’s brand new so there shouldn’t be any updates available”. Needless to say I’m about one or 2 more CELs from returning it.
Others say theirs works flawlessly. I’m not that lucky.
Disconnect the thing and see if running issue clears up and/or then get code from onStar.
Exactly what I plan to do tomorrow. Didn’t feel like messing with it tonight as I have a small shim in the negative terminal (because it fits loose) and I don’t wanna lose it [emoji3061]
36 minutes ago, Jav_eee said:
Exactly what I plan to do tomorrow. Didn’t feel like messing with it tonight as I have a small shim in the negative terminal (because it fits loose) and I don’t wanna lose it emoji3061.png
Shim? Negative terminal? Sounds like a source for a problem.....
After 2 dead batteries, one being on a “new” battery because the first was blamed on a bad cell, I investigated on my own and found the negative terminal was looses even when tightened all the way down. I put a small piece of metal in between the post and the terminal to take up the slack. I can assure you it is not a source for a problem as it’s been 7,200 miles since...
10-4. My first though was that you'd shimmed a terminal in one of the connectors... Rather than the battery terminal.
My truck recently did a software update on its own. I was prompted to initiate it when I had about 15 min. to complete it. My question is does anyone know if we would have to unplug this device every time GM sends an update to our trucks?
Got it installed yesterday afternoon and it’s a night and day difference. The one I originally got had a dead pedal lag kinda thing. This one does not. No CEL either. Haven’t tried adjusting the throttle setting on the fly, I’ll do it today though..
I tried to install mine this morning.  As soon as I turn the ignition on I get reduced engine power, ESC and parking brake errors.  Range is sending out another one.  Bummer.
-Eli
-Eli
It’ll be worth the wait.
I got mine from Diablo.  No difference I'm sure.  Worked great.  Only odd thing is I can't shut off start/stop with dash switch when unit is hooked up and set to not disable it. I can disable it through the unit as designed though.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
