I emailed Range. They said they do not have the ability to add any further features to the Pulsar.
30 minutes ago, Jav_eee said:
just got mine, it’s packaged nicely...
Thought it wasn't due out till the end of the month.....
47 minutes ago, Jac365 said:
When I change my truck to sport mode it stays in sport mode until I change it to something else. I. will put into touring for long highway trips but otherwise I leave it in sport mode.
I would love to delete the auto start, raise my speed limiter (currently 98 MPH) and have the ability to stop DFM from being active at my discretion. (Inspection state, ran into issue with old truck and Range device)
That's a first. Does the green checkered flag icon stay when you shut it.off and start back up?
Well, install problem #1.
The supplies connector and the OEM connector do not agree with each other. This blue tab (present on the stock side) doesn’t go in correctly.
Negative. Flag is visible when first put into sport mode. Subsequent start ups flag not visible but a check of the drive mode shows it to still be in sport. It does not default back to tour.  I first thought it had because no flag visible, but upon checking mode it stays where it was last set.
Filed down these two tabs a bit and all is well. Install, my issues aside, is easy. Fifteen minutes tops!
What is your vehicle that you installed it in? Aside from tab issue is it user friendly?. And silly question. Does the Pulsar stay in plugged in permanently or is it used like an OBD scanner and disconnected when done. If permanent does everything revert back to factory if Pulsar is removed or fails?
2019 at4 6.2
Super user friendly. Stays connected under the hood. Supposedly invisible after it’s removed.
I’m having some issues with it though. When toggling through throttle settings while driving I got a whole bunch of warning lights. I mean, almost every warning and light on the dash. I’ve emailed tech support about the issue.
29 minutes ago, Jav_eee said:
2019 at4 6.2
Keep us posted. I have a 2019 AT4 also (5.3) and am seriously looking at this unit to modify my current settings.
Will do
Its not in Sport mode if the flag isnt there.  When you turn the dial to "check" the mode it switches.  Every time you touch the dial it changes a mode.  Normal mode is enabled every time the truck is started unless you are in Tow Haul and restart within 2 hours. (I think its 2 hours)
-Eli
I watched the video on how to change things and I didn’t think you could change things while the truck was running, or driving for that matter.
Responsiveness Level Adjustment
When the vehicle is running and cruise control is turned off, the vehicle throttle responsiveness can be adjusted. The responsiveness level is indicated using the vehicle’s speedometer.
STEP 1 - Using the +RES or -SET, adjust to the desired value.
Level 0 = Stock
Level 1 = Reduced responsiveness (up to 15% less than stock) Level 2 = Increased responsiveness (up to 15% over stock) Level 3 = Increased responsiveness (up to 30% over stock) Level 4 = Increased responsiveness (up to 48% over stock) Level 5 = Increased responsiveness (up to 65% over stock)
STEP 2 - To recall the vehicle’s performance level, press the cancel cruise control button.
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 761 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
