13 minutes ago, Thejet07 said:
So anyone get a cel from the pulsar Lt?
Not for me.  What was the cel you received?
I had several codes:
p0100
p0101
u25a2
u1346
i took off the pulsar and drove around and it seems they may be clearing. I wonder what the issue is?  I may install it again and then drive it and see if it clears.
update: just went to pick up daughter from track and codes are all gone. I wonder if somethings may be wrong with the product. Two questions. First, did anyone connect theirs to the computer to update and secondly did you disconnect the negative terminal and for how long?
Edited by Thejet07
p0100
p0101
u25a2
u1346
I did not connect to update and it is recommended to disconnect the negative terminal.  Mine was disconnected for about 20 minutes for the install.
I did not update and I did  not ever remove the neg terminal I never saw that in the instructions to do so, however I have removed a few ecu's and never disconnected the neg just for that.
On 4/28/2021 at 3:21 PM, Robby James said:
No, I have installed and uninstalled mine 3x now no CEL as of yet.
I have ran premium and regular unleaded with it installed.
Question on the dis-install, do you have to change settings back to stock? Or just unplug it? I’m gonna be ordering one for my truck, but want to remove it when I take the truck to the dealer for maintenance/state inspections and if I need any warranty work done.
I just unplugged and replugged in the factory connections, never unhooked battery etc never had any issue whatsoever it HAS been to the dealer for an oil change since install/ uninstall.
  • 2 months later...
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 461 Guests (See full list)
