I received my PULSAR LT unit yesterday and installed it today. Installation went smoothly with the exception of not being able to get connector off of stab on air filter box. I could not get it to release because I did not have anything handy to slip in and release catch so it would slide up. When I get home I will get it. So far I have perimeters I am interested in programmed and will report back after I have had it in service for a couple of weeks.
Well I just hit 1,000 miles with my range pulsar lt and so far so good! No issues whatsoever. I really love the improved throttle response and I've noticed with the DFM turned off that the idle is way smoother. I figured I have lost about 1mpg with that disabled, but to me it is worth it.
They just called me today to say they found a bent pin on the first unit they sent me and haven’t been able to replicate the issue with the second unit. They overnighted me a whole new module “special built for me”. Haha hopefully this one won’t have issues...
Totally agree with DFM off and throttle response, however I had to send mine back due to problems.
I will wait a few months and see if things smooth out and maybe order again.
Tom
Nice! Good to hear they are making it right with you. It speaks volumes about their customer service. Let us know how the new one works  for you.
  • 3 weeks later...
Any updates to this?
The past week my truck has stalled out a couple times, not sure if this is because of the Pulsar but if it happens again I'm going to remove the Pulsar to see if it happens again.
Funny you mention that.  I was in a drive thru about 3 weeks ago with the truck in drive and idling and it just shut off. I put it in park and it started right up again. No CEL or codes and it hasn't done it since.
What were you doing when yours stalled?
Very interesting. First time I put her in park while I was getting the mail and when I put her in drive she died on me. The second time I was stopped at a light and she died. Starts right up after the shutdown but I am noticing that the RPMs are very low when stopped. Yesterday I tried to update the software but still no new updates available.
I was on the road today and my truck stalled multiple times. I removed the Pulsar and the truck ran fine but now I have a check engine light on. Going to call Range to see if they have any ideas.
I never had that issue. Well, mine has stalled maybe 2 times since I bought it but it was before the pulsar was installed. Once while fueling up (yeah yeah) and the other was sitting in a parking lot.
As for the device, I sold it because I just feel like my truck has too many electrical demo so tolerate it.
Not trying to be a Pulsar salesman, but I would ask anyone having problems with the device to remove it and put dialectic grease in the prongs of the connector.  The stock connector is a poor design and has a rating of being plugged/unplugged five times.  I've seen stock trucks come in with odd random electrical issue, like stalling, no start....  and it ends up being in the connector/prongs in the connector that the pulsar plugs into.  So it is delicate and combine that with being torqued on trying to get it apart to install it, it may develop an issue a connection issue.  I watched the video about 3 times and the install went super smooth, and it hasn't come off, fearing any issues.
I have 3K miles on mine now with no issues.  I do NOT use the throttle mapping.
-Eli
Ok I investigated my issue and it looks like it was self induced. I did not tighten my Rotofab CAI tube and it came completely off. I tightened up it up and reinstalled the Pulsar and the truck ran great during my test drive. I will keep an eye on both but again it looks like user error. I'll also look into some dialectic grease.
Anyone have anymore updates on how theirs is performing? Specifically on a 6.2...been thinking about getting one but still on the fence due to some of the issues raised here.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,335 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
