I don't think it's meant to be used when driving, but the truck does need to be running.
Edited by Daly
1 hour ago, Jay P said:
Responsiveness Level Adjustment
When the vehicle is running and cruise control is turned off, the vehicle throttle responsiveness can be adjusted. The responsiveness level is indicated using the vehicle’s speedometer.
STEP 1 - Using the +RES or -SET, adjust to the desired value.
Level 0 = Stock
Level 1 = Reduced responsiveness (up to 15% less than stock) Level 2 = Increased responsiveness (up to 15% over stock) Level 3 = Increased responsiveness (up to 30% over stock) Level 4 = Increased responsiveness (up to 48% over stock) Level 5 = Increased responsiveness (up to 65% over stock)
STEP 2 - To recall the vehicle’s performance level, press the cancel cruise control button.
Level 0 = Stock
https://www.diablosport.com/shop/pulsar-lt-control-module.html?SID=ar1urpceqg0bla7qm0otbvl6k2
i should have paid better attention through the whole video.  It still doesn’t say anything about driving while adjusting power levels.
Edited by SILVER SLED
It’s advertised as “on the fly”.
On 11/6/2020 at 6:10 PM, Jac365 said:
Negative. Flag is visible when first put into sport mode. Subsequent start ups flag not visible but a check of the drive mode shows it to still be in sport. It does not default back to tour.  I first thought it had because no flag visible, but upon checking mode it stays where it was last set.
I tested this.. It indeed reverts to normal mode. I put mine in off-road mode before parking this morning. Got back in today, turned the knob, and it went to sport mode. If the first turn displayed the current mode, then it would show off-road. However the first turn takes it to the next mode. So if it stayed in the last mode, it would have gone to normal mode, not sport as it did.
Maybe the '19s were different, as I believe the switch and displayed modes are different. The '20, the switch is turned to left to get to tow-haul mode. Where as I've seen pictures of the tow-haul mode being in the drive mode list. Mine just has the three, normal, sport, off-road. And then the turn to the left gives tow-haul mode.
2020 manual says:
Sport Mode
Use where road conditions or personal preference demand a more controlled response.
When you enter this mode you will immediately feel a down shift.
Maybe the 'immediate downshift' is another way to determine/verify if it woke up in sport mode.
A flag on the dash is the only way to determine if it’s on during startup. The only made that will be present on startup other than touring is tow/haul. All others revert back to touring.
Just picked up my 2020 6.2, very interested on how well this works.
Edited by RRonin
Ok I called them this morning. The tech, who didn't sound too sure of himself, said "while parked, not driving". That's not very "on-the-fly" but it is what it is. I haven't gotten any warning lights after leaving it alone.
2 hours ago, jddealer said:
What's everyone's take on the Pulsar vs the White Automotive product?  They have some similar adjustments, yet some different ones as well.  The White Auto. is cheaper, but you don't own it.
https://www.whiteautoandmedia.com/product/t1-pickup-wams-spec-bcm-programming/
The White auto doesn't do anything for auto start/stop or DFM. It only works on the BCM.
Jay
Mine worked fine all weekend after the small problem I had when using it “on the fly” and finding out they don’t really mean that. Remote started it today and had a CEL. Onstar couldn’t give me the code, “unable to probe module”. She asked if I had anything connected to the truck. It wasn’t shifting right and surging at cruising speed (35mph).
I’m really hoping my device needs an update but the tech support person I spoke with this morning said “probably not, it’s brand new so there shouldn’t be any updates available”. Needless to say I’m about one or 2 more CELs from returning it.
Others say theirs works flawlessly. I’m not that lucky.
That stinks! I had high hopes for this. I was about to order mine, but I may wait to see how this plays out. Can you use the Pulsar unit to pull codes?
You cannot, unfortunately. Only thing it does in regards to DTCs is clear them.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
