18 hours ago, OnTheReel said:
The squeak and the leak is all that bugs me anymore.
If you asked me at any time during the first 3 months of 2019, I would definitely tell you it was the worst, least dependable vehicle I’ve ever owned. The glitches were almost unbearable. Trailer disconnected alerts literally every 5 seconds in cold weather, tons of infotainment bugs, “service steering column lock”, brake loss, flashing check engine lights.
These were really a leapfrog design, it may have been rushed to market, and it definitely took a lot of refining. But I think they are damn good now. And they will unbeatable in 2022 after further refinements.
Tell me about your “service steering column lock” issue. It popped up on my truck a couple weeks ago. Made an appointment at the dealership and then 2 days before the appointment it disappeared.....
Yeah, it would pop up like once a week on mine. My steering column was replaced under warranty for an unrelated loose shifter and I never saw the message again. But there’s actually a TSB and update for it now:
https://static.nhtsa.gov/odi/tsbs/2020/MC-10172289-9999.pdf
Interesting the TSB is from February. Truck was built in September. You would think whatever the fix is would already be applied. WTF
On 12/7/2020 at 11:55 AM, CamaroVetteGuy said:
We live in a new world. If you don’t like what the news or publisher says it’s labeled FAKE NEWS!!
the Media is owned by a handful of COrporate owned conglomerates  and Foreign countries, who All  have Agendas of their own!  Truth is not something they are interested in.. thus why all news  is FAKE NEWS!
Edited by flyingfool
I don't know about you, but the first place I come for nuanced political and medical facts and opinions is a forum about pickup trucks.
  • Haha 2
Interesting.. the Toyota boys seem to have a cult following.  What did you dislike?
I don't let anything non-american in my driveway, but just curious [emoji4]
Hummm interesting. Would that be made in or based in?
Based ?
Edited by Rob Mugs
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
