Can't tell you what to get but can share my general feelings when it comes to this debate:
1. I LOVE my 3.0 Duramax and happy I got it.
2. Sound - purely personal feeling, some love that good V8 sound and can't blame them one bit. Not a big deal for me, I actually really like the diesel sound. This 3.0 is very quiet which I also prefer. Others will certainly disagree.
3. I just changed my fuel filter for the first time at 25K+ miles, and I've done a lot of towing. You probably won't have to replace yours within the first 2 years and it's only like 100 or so bucks at dealership <1/2 penny per mile
4. Price of DEF? it's like $2/gallon and you don't fly through it unless your towing heavy loads a lot. Doesn't sound like the case in your situation. Put in a couple gallons every thousand miles at call it $5 total... Is this really a deal killer when you're buying a $40K-50K-60K truck?
5. Price of Diesel? In my experience it's been significantly cheaper than Premium gas and it quite a few cases actually cheaper the Regular gas!
6. Longer warranty on the 3.0 engine
7. Towing capacity? Be realistic how big a boat are you getting? If you're never going to tow anything that pushes that higher limit then towing capacity debate is irrevelant. It would be similar to saying the 6.2 max speed is 130 mph but the 3.0 max speed is only 120 mph. Advantage 6.2. Do you ever EVER plan on driving 120+??
Cheers! ?
19 hours ago, Leevon said:
Can't go wrong with any of them.  I'd be concerned about the long-term repair cost potential of the 3.0 though.  Anything with a 10-speed...8-speed is a turd.
3.0 and 6.6 comes with a 5 year 100,000 mile powertrain warranty, vs 60,000 5 year powertrain on the gassers.
Bumper to bumper is still 36,000 3 year on them all.
https://www.gmc.com/owners/warranty-details
Agreed on the new 6.6L gas motor. It’s gotten great reviews. Lots of power. It just needs the 10 speed backed behind it to unleash it’s full potential. I don’t understand why GM isn’t putting 10 speed in all their vehicles?
This is why I'm hesitant on getting the gasser. They have also changed the gearing from 4.10 to 3.73.
Sent from my SM-G981V using Tapatalk
1500 one is too light
25/3500 one is too heavy.
They need a 3rd one that is 'just right' for the HD duty cycle at the LT8 torque level.
Edited by redwngr
So your thinking like I have thought that GM should bring back the big block 8.1L behemoth??  I totally agree
Nope.
It's 8.1 was no where near the torque capability of the HD 10 speed either.
6.6L LT8  401 Hp  464 ft-lb
8.1L L18  340 Hp 455 ft-lb  (for 2001/2/3;  2004/5/6 were lower)
I'm thinking they need a different transmission to match up with the LT8
They do have the 10L90 that handles 650tq in the ZL1. Seems like it would slot in nicely between the half ton 10 speed and the “Allison”.
But it all comes down to money. And that there’s no requirement to report fuel economy the HD segment, thus no reason to increase efficiency.
On 12/8/2020 at 3:43 PM, steelcity said:
5.3 mated to the 10 speed is a game changer.
Drove both before I bought the Trail Boss, L84 5.3, 10 speed. Way more zip than I thought it would have. It's fantastic! I love it!
On 12/8/2020 at 11:20 PM, leverett.scott said:
I love the 5.3, but I don't think you can get the 5.3 with the 10 speed in a Silverado, only GMC.
Correct me if I'm wrong.
Your wrong. I have 2020 Trail Boss 5.3 L84 10 speed. Love it.
I have a 2020 LT with the 3.0, slightly over 16K so far and zero issues. Averaging 25-30 mpg on highway and have gotten as high as 38 with a good tail wind. Def usage has been minimal, have not added any between oil changes which I do every 5K, usually takes about 4 gallon for 5K. Fuel filter life was showing 44% at 16K when I had dealer change it at last service, cost $100 to have dealer do it which isn't really bad figuring you should get at least a year out of one although I will do the next one myself as a filter kit online is only $25 and it takes less than 15 minutes, this I plan to do yearly. The price of diesel and the higher octane gas is usually comparable to one another in my area although 91 octane is the most prevalent, 93 is scarce in my area. I would say that 80% of my driving is rural as I live in a rural area and do a lot of hunting and short trips to the farm. So far I am very happy with the 3.0 and 10 speed combo, this coming from a 19 Trail Boss which I had a lot of issues with.
Instantaneous torque capability isn't the same as 'long period of time' torque capability.
Duty cycle requirement in the HD segment will have a much higher percentage of full load than in the sport world.
16 hours ago, redwngr said:
Nope.
That’s the old 8.1L power number
with direct injection and other new technology they could get 500 HP out of 8.1L
and the 10 spd would be perfect for this engine and even the 6.6L gasser.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
