SOLD - $200.00  Truxedo Lo Pro Tonneau.  Fits 2019(nbs) - 2021, Double Cabs.  Used approximately 18 months.  Excellent condition.  I can send photos if interested.  Local meets to 48611 only.
Edited by ejdziurka
