Well, my truck finally moved up to 3400 - thank goodness.
Still have a ways to go I know, but at least I'm not stalled out at 3000 still.
C'mon baby! Fingers crossed no more delays! (Yeah right, lol)
On 4/8/2021 at 10:44 AM, nards444 said:
Ordered 27 FEB
4 MAR- 3000
26 MAR- 3300
1 APR- 3400
8 APR-3400  But have a VIN and truck is built.  Odd its at 3400
Interesting, I ordered a 3500 AT4 in Early January
3000 - March 2
3300 - April 2
3400 - April 7
It is apparently getting built next week.....
Flint and Fort Wayne are shutting this weekend due to chip shortage.  GM is doing everything to keep the plants running but some of the options maybe limited.
#iworkforGM
Shipping company called dealer Monday morning to see if they would like to pick the truck up or wait until they had a full load to drop off to them. Dealer picked the truck up and I picked it up Monday evening.
That's great, Congrats on the beautiful truck. I just found out mine arrived yesterday, is going through PDI today and I'll pick it up tomorrow.
Ordered 27 FEB
4 MAR- 3000
26 MAR- 3300
1 APR- 3400
8 APR-3400 - Truck was built but for some reason the system didnt show 3800.  VIN was provided
15 APR 3800
No update for shipping yet.
Edited by nards444
Congratulations. It’s so tough waiting. Look Great!!!
Thanks and I am sure you are glad the wait is finally over for you.
Thanks and yes it wasn’t fun waiting on it to be built and then arrive.
Picked it up yesterday and yes I’m relieved  that this is over. Things just got crazy with the wait and constraints and not knowing when the truck would be built. I’m glad I made the call to cancel my order find a truck in route.
Congrats and I am sure you are beyond happy the wait is finally over.
From someone who works at Flint (not assembly).
Quote
Flint built HD's are scattered around area secure lots awaiting shipping. A shortage of rail cars.
I think were going to be in a summer surge.  Lots of government checks in peoples hands and spending is going to go through the roof.  Be a busy but good summer for truckers.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
