Same exact thing happened to me with my free first oil change from the local dealer. They blamed it on a bad filter.144c51d4998a16378e7c8a21ba12b5e4.jpg
Sent from my SM-G998U1 using Tapatalk
That’s unfortunate.   Hope it is nothing but a bad filter.
I always considered changing my own oil.   I find there is this conundrum if you want to sell your truck (privately) later on.   Potential buyers like to see dealer maintained vehicles with all the records.  Yet present owners like to do their own oil changes.  I guess it doesn’t matter if you trade it in.
@JimCost2014 not in my case, the filter was tight as I tried to tighten it myself.  They claimed they have seen it before and that there are small cracks in the filter, said it's a known issue.  Only reason I used the dealer was it was free and I also needed them to program the keyless entry pad I bought afterwords.
Common denominator appears to be AC Delco filter. I've used nothing but Wix on all my GM trucks and never seen that happen.
I have been using these filters and never had an issue. I always inspect before I install but anything mass produced will have defects. I’m also wondering if the gasket was stuck on the block from the previous filter and the tech didn’t realize it. I have seen them leak when that happens. Just a thought.
Wasn't a double gasket on mine, I went back there with the truck, tech, and service manager as I was going to raise a stink if it was doubled up.
Likely a fool not oiling the gasket prior to application. Never install them dry. Never had one leak in 30 years doing it properly.
  • Thanks 2
I did the double gasket boo-boo once. You definitely only do it once. Shot about a quart onto my driveway within few seconds. I always look down there after starting the first time so I caught it right away.
Anywho, there’s no way the leak in question was a doubled up gasket. Wouldn’t make it 2000 feet let alone 2000 miles.
I never let the dealer change my oil, especially if it's "free".  Same goes for jiffy lube places and independents.  I do my own and have never had an issue in 50 years.
It's never 'free'.
They are in the purchase price.
I like to change mine too, but I'll let the dealer do the ones I already paid for with the truck.
Filter failures are rare, but they do happen.  When one is gonna fail, it doesn't care where the change was done.
Bingo.  A dry gasket will stretch and tear on install.
Edited by Gangly
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
