Apologies if this has been asked before, but haven't found it by searching yet.
Last weekend I was driving up the 395 and after filling up a tank of gas, tried to start my new truck (2021 w/ <4k miles). I pushed the start button once and the starter engaged with a weird cranking noise that continued until I re-pushed the button to stop it. Tried it two more times with the same result. A guy in an LT Trail Boss behind me heard the noise and walked over. He said its happened to him 3 times in 15k miles and that the only thing he could do was wait it out, try the unlock/lock buttons on the keyfob, and it would eventually work. Sure enough after about 3-5 minutes it started up.
Recall in the works? Anyone else faced this yet?
There is thread called “Won’t Start”.It has over 12 pages of posts. The same thing happened to my AT4 yesterday morning.I only have 455 miles on it. I’m not sure it GM has a true fix. I read some had their electronic control module replaced. Look through that thread. It didn’t make me feel good about the issue.
1 hour ago, khays said:
Where did this come from? GM memo sent to dealerships?
I would assume so. I download so much information, 90% dealing with farming, I have no remembrance where I actually found this.
Mine is a '21 and when I re-torqued them I got 3 turns out of the bolts. I had no issues, just checked them. It was below 0°F, when I checked.
That is absolutely ridiculous for a new vehicle with an already known issue. I'll re-torque them and see what happens.
  • 4 years later...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
