Hello !
I am new to the forums and am starting to build my 2001 Chevy Silverado Z71 as a fun daily driver. I purchased the vehicle after the original owner crashed it. (rear ended someone)
Now I am looking to fix it up as my new daily driver. My goals for this build is to learn more about the 4L60e transmission and what is needed to rebuild it properly, as I plan on adding more power to the 5.3LS
Truck currently sits at 180k so a tune up is in order first before anything brakes, fluids, belts ect. . I am posting my truck up into the forms for your guy's experience with these trucks.
 I have already painted\replaced front bumper, grill, headlights, fenders,  and found a HD hood I found at a local pull and pay.
I would like to lower the truck next, although I do not think C-notching is a great idea?? <<<Correct ME If I'm Wrong.
Does anyone know what the lowest drop you can go with WITH OUT having to C-notch the frame is? I am not against C-notching I just never have  don't think it would be a good idea to cut a frame on any car? I could be wrong, Thoughts?
What's a great place to start rebuilding my 4L60 transmission? My goal is to eventually hit 400 WHP with the truck. But from what I have read I wont make it there with the stock 4l60. (4L80 is definitely the way to go, BUT with this truck being 4WD I would rather keep it simple and just rebuild the 4L60 that is in it. I fell 400 is more on the conservative side and can be accomplished with the 4L60e.
Anyways if you have made it this far thanks for checking out the thread!
-Ryan
You can only go 4 inches in the rear without a c-notch. That would be with a rear shackle drop, front hanger drop and I think the 4X4's have a factory lift block so you'd technically get a little more drop.
Your other option is a flip kit for that same drop but I'd probably want the leafs on top of the axle still.
The front you can do lowering spindles and slightly crank down the torsion bars for an easy 2 or 3in drop.
Edited by CamGTP
Seen a kit that Summit, Lowering Kit, 3 in. Front, 4 in. Rear,
https://www.summitracing.com/parts/bel-664nd?seid=srese1&gclid=Cj0KCQjwppSEBhCGARIsANIs4p6fPDne7gF8BCP8e3iF14vaFSVd7OO_NrRUL-m4MmuTKvK0atzYX-UaAqWzEALw_wcB
Didn't pull the trigger though,  wanted to see what others though, I am still running the stock wheels which are 16" I don't think this should be an issue? Although I am not sure???
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
