106k 2017 5.3 6 speed
felt a slip and a bump in 3rd gear. Under moderate acceleration, heard grinding.  Limped home a few miles. Towed to dealer, results TBD.
im thinking the torque converter let go and ruined the whole trans.
history - chuggle TSB when the truck was new. Flushed at 50k at the dealer. Dropped pan at 100k and changed filter / replaced lost fluid with fresh dex 6. Pan was clean. Fluid looked great. Not much on the magnet. Looked brand new inside.
90 percent highway miles. Maybe 3000 miles towing, nothing more than 5000 lbs. don’t haul much. Don’t overload when I do. I don’t even drive it really hard....maybe mash the go pedal once a month.
aftermarket converters - what’s available?
what stall is the stock one?
hoping extended warranty covers this.
anyone with any thoughts / comments / inputs?
thanks.
mike
Sucks that this happened.  It will be interesting to see exactly what the cause was and what happened.
Just rebuilt mine at 109k. 2014 Silverado 1500, 5.3l, 4x4, CST 4.5" lift, 35x11.5x20 Ridge Grapplers, 3.42 gears. Same issues and duty cycle you are reporting. However, I bolted on a 1.9l supercharger at about 105k. That certainly didn't help this fragile tranny survive. All billet parts and upgrades, 1800 stall billet TC. Hopefully, I can get 150k out of this one with the SC. We'll see. $6.5k is tough to swallow at 100k on these trucks. Truck was pretty much stock up to 90k miles.
They aren’t tearing it apart but doing a full replacement. Extended warranty company has to come check it out before they authorize it.
where did you get the converter? What was the lead time?
$6.5k is easier to take than $60k for a new truck.  :)
Edited by Black02Silverado
spelling
In your opinion, which of the Big 3 builds the most-durable transmission right now? Is Ford F-150 6-speed any better, or Ram 1500 8-speed?
  • Haha 1
Were they serviced? Fluid changes? Just curious.
Mine at 30K...was planning another at 100 before my issues started.
I wonder how many more transmissions will die before it gets understood a Group III mineral oil will not take the temperatures the OEM thermostats are asking from them?
  • Like 3
  • 1 month later...
Your extended warranty company will not pay to rebuilt your trans. unless they can get a warranty like a 3yr/100k. What they will end up on doing is get the dealer to replace it with another GM trans. off the self if available because it will come with a 3y/100k warranty from GM. Now you will have to talk to your service manager if you can replace the torque converter with a billet aftermarket one (which I don't think they will cause of warranty reasons). If there enough metal in the pan your extended warranty will give the gone ahead and replace it. While you have the trans. out have them check your rear main seal if its need replacing.
How I know this because it has happened to me at 109,144 was 150 miles from the dealer got lucky an found a good tow company that only charge me $230 for the tow. I don't know who you have for the extended warranty, but make sure your service rep. keeps in daily contact with them, it also helps if they know the extended warranty company. Did you buy your extended warranty from the dealer, if so talk to your sales rep. maybe they can help on getting you a new trans. Good luck.
lots of other GM trucks have suitable converters, could try aftermarket, but I bet you biggest issue was heat not the converter. you can go all the way back to a 2008 1500 truck  , Blazer SS models with 6l80 or a 2500 HD truck with 6L90e trans, some guys are using CTS-V for more power abuse those are 2200-2500 stall I think
1900-2000
I'm toying with going to a lower stall and completely disabling the lock up converter controls  maybe a 1300-1600 rpm , they did this in the 70's before TCC was utilized
doubt it
I would install a trans cooler and keep an eye on temps with the DIC gauge
Edited by pokismoki
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
