I had the same problem this weekend, took it to the dealer to inspect the brake system.  We almost had a accident on the interstate, took a lot of work to come to a stop.  (my thoughts, $80K truck should not have to pump your brakes to stop this vehicle)....
Peacemaker
There was another thread about this... Go out and start your truck but leave it in park, push the pedal to the floor hard, all the way then remove your foot and let the pedal come all the way back up, two or three times is what I did. This fixed the issue for me as well as others.
Do exactly what bird_dog0347 suggested. It definitely makes for a big improvement on brake feel and I've pretty much forgotten that it was an issue since I performed those steps myself a few weeks ago. Not sure why it works, but it does.
So I read this message yesterday and said what the hell, lets try it.  What do i have to lose.  Surprisingly, like bird_dog0347 suggested it worked!!  Major improvement.  I don't know why but makes me want to understand what made it change and can it be better.
On 6/2/2021 at 3:59 PM, Grjfer said:
Just throwing this out there, but after driving the truck for almost a week now I have found that a single pump of the brakes immediately provide a firmer pedal.
I have new 2022 GMC 2500 HD AT4 6.6 Gas and one pump will bring the pedal to where it should be. I have only 753 mi and been this way since I picked it up last week. The dealer offered no solution.
This process did work well. I now have a full pedal on first touch.  It appears to be related to the booster/master cylinder interface. Just to note my truck is brand new, 758 mi now.
Me too! I remembered this comment when I took delivery of my truck a month or so ago, had 4 miles on it. Pushed the brake peddle to start, and it almost went to the floor. Followed these steps then, and has been fine since.
Well I'll be damn. Just did this to my new 22 gmc 3500hd drw. It now has a much better pedal. I can't believe the pedal will bottom out to begin with. Not your normal hydraulic brake system that I know of.
Turning wrenches since '76. Never seen anything like this. Will be talking to the hd department at my local dealer, when they update the tcm, after the new years. Will report back, if he has any idea what is going on.
I'll be damned as well, didn't really think my truck had a issue just figured that's how it was. After reading this thread went out to the shed and damn if my brake doesn't feel 90% better. Thanks for the tech tip.
I have a theory that GM is using ceramic pads on the truck to stop brake dust from discoloring the rims..  ceramic pads are not good when cold, they love heat, but the problem is heat will deform the rotors so then when the pads are in the correct temp window, the rotors start over-heating and causing brake pulsing..
I will be ordering a new set of rotors , and a set of aggressive non-ceramic pads from EBC, not sure what color pad to use yet , i have to give EBC a call and talk with the tech guy
Edited by pokismoki
My 2021 GMC HD also.  I actually took it in to have them check it, TWICE.  They say no issue.  But does seem to take a lot of of pedal push to get it to stop.  If i pump the pedal once, it seems to stiffen up and work like it should.  That's why i took it in.  First time they said they bled the breaks and seems to help for a couple days, then back to the way it was.  Second time i took it in, they said no issue.
First time I put my truck in drive in the garage, I just about hit the garage door.  Was used to the pedal pressure from my half ton when shifting from park.  The new 2024 takes a ton of pedal effort at rest.  Will try the three hard pumps thing and see if that improves things.
Just Had my brakes replaced at 23003 miles for the brake squeal. I have always noticed the weak/soft pedal feel since owning the truck. I even did the push the pedal to the floor hard, all the way trick and it helped some but I found it did not say that way. Since getting the brakes replaced I will say the pedal feel is much improved now. Not sure why, but I'll take it.
Add me to the list of "wow, it worked!". This is my first HD truck so I just thought that's how the brakes felt, but this really firmed them up.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
