System fully installed. I did keep switch 1 on the on position. Was getting a vibration from the sub that i traced to the mounting bolt for the lug nut bag. This was fixed with a separate bolt and washer to secure the sub separately of the large wingnut assembly . Mounted the bass knob in my console with in easy reach of my hand.
  • 3 weeks later...
Any chance anyone wants to share a little video on where the sub wires are and how you got to them? I think this could make install much easier for most.
I will if I ever get time to actually do it. I've been so happy with the performance of the sub since getting the gain set up right that I haven't been too motivated to change anything.
For the Bose sub wiring, which is positive and which is negative?
And did I read correctly in this thread that its actually a line level signal at that point? The wires shown in the pictures on the first post?
I managed to get it all wired up today and took some video that will hopefully help. I do need to run the amp harness under the carpet and then plug it in and adjust eq and put the fuse in and then I am live. Hoping I will find time to finish it up. If all works okay, I will then get the videos up. For the time being I plugged the green wire into the green with black stripe wire and the brown wire of the harness into the blue wire with silver stripe.
Alright…. Now I’m frustrated. So I felt like I have not gotten hardly any extra bump and what found is once I start to get it up loud enough to do anything the sub stops moving. The amp power led is still green but sub will stop moving until I turn it down enough again. My door speakers are out performing the subs with the bass setting at zero. I tried adjusting the bass knob, removed the bass knob, changed the dip switch settings to see if I can find something that works with the gain and nothing. I started with 1, 4,5,6 on and then tried just 4,5,6 on. When neither produced good results I tried all sorts of combos and got nothing. Any ideas?
Decided to move it to the yellow wires for the rear passenger door and now it works fine. I think there may be a flaw in using the sub wires. Anyone else want to test putting your fingers on the surround have someone turn it up and see if sun stops moving until volume goes back down?
Sigh…….. spoke too soon. Same thing happens no matter where I plug the inputs in. It seems to be able to give a little more output on yellow wires, but ultimately does the same thing. Bass knob does very little for sound. I can feel it cause more excursion but sound output is pretty minimal. Now I have to wonder if this is a phase thing. Still running 1,4,5,6 on for the dip switches.
anyone have any thoughts? I’m so disappointed :(  I hope there is a fix and this isn’t just really poor output.
Sounds like your amp is faulty.  Phase would have nothing to do with it. Mine never cuts out.
Edited by Tjeli
What trim level is your truck? Do you have the Bose system? Are you sure you were connected to the correct wires for the inputs? Do you have your head unit Fader/Balance/Basd adjusted in an extreme way(start them all at 0 until you've isolated this problem)that may be under/overdriving the speaker that the amp is getting input from?
Switches 4-6 should all be in the Up position. Start with switches 1-3 also in the up position, without the control knob connected. This should give you tons of output from the sub, and be overpowering. You can then turn switches 1-3 down, up to having all three down to decrease the gain setting, and/or connect the control knob to adjust gain.
Being that this is all plug & play, other than the speaker level inputs, I'd be suspect of them the most. If you do suspect it's out of phase, swap the two input wires, but that shouldn't result in a total lack of output.
  • Sierra Denali
  • Has Bose
  • Fade/Balance was/is Centered
    • Tried adjusting it and same result. Once you go far enough in any direction it will eventually just cut out as well
  • 4-6 all up. I have tried 1-3 all up as well.
  • I have swapped the leads thinking that should fix phase also and nothing...
  • I am beginning to think the amp is faulty as well. Going to try and call kicker today. My only fear is there is some protection kicking in and it doesn't seem to take much for it to get there. Im pretty sure door speakers should not overpower the sub :(
yeah.... thats what I am afraid of. I am going to call Kicker today and see what they think and go from there.
1 hour ago, Thomas Rodriguez said:
  • Sierra Denali
  • Has Bose
Yes, this sub, with the gain all the way up, way overpowers the rest of the speakers. It sounds like you've covered everything, and there is an issue with the amp. Please keep us updated on what you find.
Just curious, I'm getting ready to rewire my Kicker sub but looking at the original photos and then reading the wire color configurations, there looks to be a mismatch.  The photo shows the Kicker green wire connected to a white wire that is then connected to the blue wire but it was stated that green connects to green?  Just need some clarification before I dig into this.  Also, does it take much to take the console apart?
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
