Hi guys, just got a ‘20 Silverado 1500 LTZ, love it! When I open the rear door after the truck has been off for a while, a motor activates that sounds like it might be from an electronic running board. The truck didn’t come with running boards (it was used, though). Is this noise normal? Any ideas of what it could be? I have to check and see if it does it when the engine is running, I guess.
It should happen on any door you open I believe. Pretty sure it's the fuel pump priming the system.
  • Thanks 2
Hunh, I have never had that in 30 years of truck ownership. My last Chevy was a ‘13. Glad to know it’s normal, if a little distracting.
30 years ago we didn't have the pressurized fuel injection system that is used today...
What engine is in your truck?
If it is the 6.2 or 5.3, it is just the fuel system priming like other have said.
I think its the fuel pump priming, or the fuel tank system releasing pressure. As I always use my parking brake so it's already engaged  when I open a door. Plus they sound different to me.
Its the fuel pump priming.  The parking brake creates a noise near the front bulkhead of the truck and is often associated with a click sound as well upon completion of activation.
Yes, it is the fuel pump.  On the newer vehicles with direct injection, GM wants to make sure the high pressure fuel pump doesn't start dry.
I have heard the same thing on 19 and 21 Silverado.   It is the fuel pump.   Pressing the door button without the keyfob on you and the you will hear the fuel pump turn on.
My brand new '21 Sierra does it, sounds like the fuel pump priming, but if not that, something spooling up.  Normal.
My old '07 Yukon has "spooling up" sounds when I open the driver's door.  The CD starts searching, etc.  They have been doing things like this for a long time.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
    • Typically it is the Torque Converter, I have a 2.7L Trail Boss and between 25-65 MPH at 1300-1500 rpms under light throttle it has a shudder which I almost consider and bobble or a gargle sound. They replaced my TC but it did not help any, others say it has fixed their issues. It has been back twice now with no fix after.
    • Still $3.01 with even more places at this price
