I got a set of red recovery hooks for my 2022 crew cab and I can’t for the life of me figure out how to get the long bolt out of the drivers side. There is a plastic shroud in the way.  I removed any bolts for the Schroeder and even took a pry bar to it, it won’t budge.
any suggestions?D50BAA45-4CB8-449A-B254-021BAA265DFE.thumb.jpeg.6e6c477367907e933a41b6f11b07a47d.jpegD50BAA45-4CB8-449A-B254-021BAA265DFE.thumb.jpeg.6e6c477367907e933a41b6f11b07a47d.jpeg
11 minutes ago, steelerdude1 said:
Giving up for today, may just put the other black one back on and be done with it. BD20ABAD-DA38-4124-BC76-22DB2B7C939C.thumb.jpeg.c4f959393db4998d7bda1d5e63535d43.jpeg
It never fails when installing something its always the last install that there are problems but if it were me, I would take a Dremel and grind that plastic piece off enough to drop the bolt as long it's a lip and not a solid piece stopping the bolt.
Edited by Silverado4x4
1 minute ago, Silverado4x4 said:
It never fails when installing something its always the last install that there are problems but if it were me, I would take a Dremel and grind that plastic piece off enough to drop the bolt.
thanks for replying ,
I tried to get a Dremel  in there, there but there is not enough room. Not sure if I can buy a long extension though.
How about a sawzall and put the new bolt in from the other direction?
Both of mine came out easy peasy and I dont recall having any plastic covering anything.  30 seconds with the bumper off if I remember correctly, so I'm not sure what's going on. Is yours a diesel?  Mine is a 5.3 so it might not have had that component to begin with on the front end if that's the case.
Edited by Gangly
I have the 2.7 turbo
I tried  that is too. Bolt just wanted to spin. Was afraid  to grab it with vice grips in case it didn’t cut through and not being able to use the bolt if it didn’t work
I’m going to try one of the reciprocating  dremels and a bolt cutter in the morning.
Edited by steelerdude1
You need to cut it out. No other way around it. Put a new bolt in after. This goes for the 2.7 and 3.0
Maybe a box end wrench?
Maybe a socket on a breaker bar?
Put the black ones on then get small paint brush red enamel paint and paint the ones you have, people put the red ones on just for show anyway and never use them, no one will know there painted. I have used mine {black) a few times and still look new I bet the red ones would look like crap if used.
I tried cutting the bolt with bolt cutters (not enough room) a long Sawzall metal cutting blade (put thread locker on, let it set up and held the nut with a wrench). That didn’t work, tried a Dremel oscillating tool with a metal blade still no luck.
Between those 065C4296-B038-43E9-9CE6-5BF2754311FA.thumb.jpeg.e44616dada8520e0df71231379a5aed0.jpeg8AB99640-83D7-432D-B9DA-376E429619B7.thumb.jpeg.99d121920ca6a8652b3b7cab23ad6cc9.jpeg2 tools, I was able to get to the plastic shroud corner cut off and finally got the bolt out. It was very tight, and I am just wondering where they get their engineers, LOL
They are finally both on now!
Had I known this, I probably would not have bought them.
You have to pull the intercooler to get to the bolts. Its a pain in the ass. I had the same experience when switching out my bumper for an aftermarket bumper. The first part of the instructions was to remove the tow hooks. That should have been the last part hahaha. Took forever.....
Gotcha, that explains it.
I cut mine with a sawzall. I was worried about it at first but I slid the bolt back far enough to cut the head off then slid right out.
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
