I was having electrical issues on my 2005 GMC Sierra 1500, which is at 197,000 miles. The issues were things like pulsing lights (interior and exterior and low voltage fluctuation (14.0v to 11.8v) so I replaced the alternator with a premium 160amp remanufactured one from CarQuest. Now my voltage seems high, sitting at 14.9v-15.2v during idle. The pulsing went away, but now it pulses when I rev the engine. I will leave it at about 1500 RPMs and it will steadily pulse until I release the gas. Is this an issue with the alternator or something else?
Is the battery light still on?  I had an alternator problem with a Trailblazer, battery light would not go off, connections were tight.  I checked continuity of all the connections to their next assembly and found that the wire carrying the pulse width modulation signal (PWM) was open.  The fault was fairly close to the connector and I fixed it with a pigtail I cut from a unit in a junkyard.
You mentioning pulsing also makes me wonder if it is in the PWM circuitry, but if it is, it is likely not an open PWM wire as that would cause the alternator to give max output all the time.
Good luck and let us know.
Another member had similar problem, but he never followed up with his fix:
Jordan... just for the heck of it run a temporary ground wire from battery negative to the truck body and see if there is any difference. I've seen this type of problem on older vehicles where the factory grounds looked good but were no longer doing the job. Won't cost you anything to try.
Well after driving the truck for a couple days, the voltage seems to start out high - 14.8 to 15.2 volts, and then slowly drop after about 25 minutes down to 12.8 and hovers between 12.8 - 13.1v. If I turn on the head lights it slowly climbs back up to normal 14.3-14.5v. I read in the manual about the RVC (Regulated Voltage Control) and I'm wondering if it's just part of that?
Yes, the changing voltage levels that you are describing is normal, but the discernible flickering or pulsing of interior lights isn’t.  Is that still happening?
A good description of the charging system can be found in this post from an Avalanche club.
https://www.chevyavalanchefanclub.com/cafcna/index.php?threads/lights-flicker.52489/
Another thing that could cause the flickering is the battery.  Just because a battery is charged to 14vdc doesn’t necessarily mean that it can keep providing current under load if it is unhealthy.  Of course this could also just be some random electrical component someplace in your truck.
My 05 has the works, heated seats, electric fans, nice radio, and I haven’t noticed any flickering.  If you’re issue was not intermittent, and you were closer- we could just swap batteries for a bit.  If that didn’t work, you could start pulling fuses to non-essential circuits until you noticed the flickering diminish.  There is the off chance that it is in one of the control modules.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
