My 4l60e is starting to show its age a bit. Not ready to condemn it yet but it occurred to me that it would not be too difficult (on the scale of trans swaps) to put a NV4500 from a GMT-800 HD truck in place of my 4l60e.
I've done a bunch of research on which part numbers I would need and it seems mostly manageable but I have run across something I can't find the answer to online.
My NP246 transfer case has the 27 spline input shaft because it's currently hooked up to a 4l60e. The NV4500 has a 32 spline output and was never (as far as I can tell) offered with a NP246, just the NP261 it seems like. However there's a part number for a 32 spline input shaft for a NP246. If I install that input shaft, will I be able to put my NP246 behind a NV4500?
Upon further research, I think it looks like the 32 spline input was installed in NP246 cases hooked up to a 4l80e in the 6.0 trucks. That means the 32 spline end would work with the NV4500 correctly but I still don't know if the planetary end of the input shaft is the same.
NP246 cases with the 32 spline input are technically called NP246HD...
I think it's much more involved than swapping transfer cases and trannys. The computeror some kind of transmission control unit is going to want to know what happened to the 4L60E. I'm sure the 80 talks a whole new language. This job was easy on a 1964 Impala, a real pain since 1986 or so.
Well I'm not planning going to an 80. I'm scoping out going to a NV4500.
I've seen that if you leave the PNP switch in Park, unplug the 20 pin, and seal it up with a plastic cover, the TCM basically just thinks nothing is up.
The VSS is in the transfer case so not an issue there.
The transmission temp sensor (on 4l60e only) and the reverse lamp switch on (NV4500 only) might give me some grief but I'm doing research still.
You don't have a TCM you just have a PCM. You will need a tune to tell the computer that your truck is a manual now
Right, yeah. I used the wrong acronym.
I do expect to eventually tune the truck (if/when I install the manual, I'm pretty tired of my 4l60e) but I've been reading other forums and it seems like other people who swap manuals into their GMT800 trucks have very few electrical problems even before the tune
The question I actually have is about transfer case/trassmission interfacing. I was hoping to confirm that the 32 spline transfer case input shaft is a drop-in replacement for the 27 spline shaft. I'm hoping I don't also need to buy the low range planetary set but if I do, I would want to know before I had the case apart on my bench
I'd be surprised if a whole new transfer case is cheaper than an input shaft and a set of clutches and steels. I'm sure it would be easier but I'm more budget-constrained than time-constrained
Maybe go on performancetrucks.net and ask this question or gmfullsize.
A few dudes on those sites have swapped manuals and I would suggest try those sites and ask
  • 2 years later...
If this ever gets seen I wanted to share that the few fellas I’ve seen pull this off was with stand alone ECU and the other had to incorporate a “piggyback” that also controlled the transmission parameterswhich was only done with quite a bit of custom tuning by way of some software wizardry….if you would like I can try n look for their contact info if you’d like….although its been nearly 8-9yrs back so I can’t promise much sir…👍🏻
  • 5 months later...
Is there any way to post a step by step process of a 2wd I'm currently trying to figure out what to do with getting the transfer case to work but ebay has the 32 spline input and the aluminum spacer and it all goes together easy. If anyone knows if it's possible to convert this tcase to a manual since the pcm ran every little movement of that thing. I'm stuck right there that's the last thing I gotta do to have it fully functioning.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
