On 1/13/2025 at 11:17 AM, KARNUT said:
2.50$ at Kroger this morning.
I’ve been paying in the 2.50s the last few tanks. Even in MacAlister ok. at 2.59. Yesterday in the odyssey I paid 2.52. I paid 2.56 in the Genesis Sunday. Krogers for the odyssey. Exxon for the Genesis.
Down another nickle on the Hi-way this am $2.72, $2.67 for cash at the truck stop
Edited by richard wysong
19 minutes ago, Likarok said:
Well Trump hit Canada with a 25% tariff on products and goods. And 10% on energy. Canada retaliated with 25% back on US Products and Goods. So expect Gas and a host of other things to increase. Auto assembly lines are expected to shut down with in a week! The hit to both economy's will be substantial!
Trump also hit Mexico with 25% tariffs as well. and Mexico has retaliated with 25% back on US goods.
And increased Chinas existing tariff by a further 10%
So the cost on just about everything will increase to varying degrees.
It all is suppose to go into affect on Tuesday. Let's hope calmer heads prevail.
In a pi$$ing match both parties get wet. :crazy:
All they have to do is seal the border and stop the drugs. And play fair with imports. Seams reasonable to me.
In Canada's case we should then send back all the Roxam Rd. asylum seekers (many thousands in the last few years) under the safe third country agreement we have with the US just as the US deports many of those who have come through your southern border. No matter what happens we all lose anyway.
All we want is fair play. Our resources have been taken a hit from a pandemic, a war and invasion of people and drugs. We need a pause, rational thinking and a reload. We can’t continue to take in people while losing industries through unfair play. To be expected to be the defenders of the dependents of the world can’t continue while our resources are depleted can’t stand. Otherwise evil will take over.
We in US are getting what we collectively voted for. Enjoy the rich getting richer and WE normies getting screwed. .50 cents a gallon avg rise in gasoline with tariffs on Canadian crude which is main feedstock for US gasoline. GM and every US automaker except Tesla about to get hung out to die.
You know what the cure is for your anxiety is don’t you? Bring it back here. There are choices right now, buy made in the USA.
