There have been threads on here before regarding the use of regular vs premium gas in the 6.2L.  I used to always use premium in my 2020 Denali.  Recently the spread between them has reached $0.80 in my area so it isn't just a couple dollars more on a fill up now.
I started using regular and really don't notice a big difference in performance.  I haven't tried to figure out the difference in mileage yet.  Has anyone done that?
I have never put anything other than L87 in my tank and have never had any pinging. My mileage seems to be on par, too. I get about 19 on the freeway. Chevy recommends that I use premium, but I recommend that I don't.
Edited by reeseb
  • Haha 3
Did this a few years back during the winter. I noticed the mpg went down. If I remember correctly it was down about 1 to 1.5 mpg.
I use premium gas in mine since I leave it parked for weeks. I don't think I've filled up in three months.
I have never used anything but 87 octane in my 2020 High Country HD with the 6.6L and my new 2022 Denali with the 6.2L.Never had a single issue and I dont expect any.
The reason is performance. The PCM is programmed with Low octane tables and high octane tables both. It will move to the low octane tables based on the ping ( KR ). The Low Tables are designed for 87. Yes, you will  have a slight performance lost, but unless you are heavy towing or drag racing it, then the Low Octane tables will handle your drive with no issues.
You knuckleheads running 87 in your 6.2s let us know when you sell your truck so we can avoid it.  Broken rings and pistons are in the motor's future.
Y'all ought to get the motor you can afford.  As for me and my house, we will always burn E85 or 93 in our FlexFuel vehicles regardless of price.  God provides for our needs.
  • Like 5
They will not. Ever heard of knock sensor? Are you WOT at every chance? Towing? If not, then nothing will happen. Also, I assure I can afford 20 dollar a gallon gas if I wanted. That doesn't mean I will blatantly piss away 10 bucks a fill up if I'm not towing or drag racing my truck. But please, tell us all how you know more than everyone else.
Edited by 1454
  • Sad 2
I put 20k on my truck driving back and forth to Jersey from NC last year and saw between 20.5 and 21.5 regardless of 87 or 93. The only thing that gave me actual more mileage was using non ethanol fuel. Which inherently makes sense because ethanol is less energy dense.  88 gave a solid 22 mpg every trip.
  • Sad 1
They do, it is not speculation, those of us who pay attention have witnessed it.
Your high compression engines knock/ping while driving around town on that 87 swill.  You cannot hear it.  You take off from a light, the motor knocks and the computer pulls timing.  You go to pass a guy, even without downshifting, the motor knocks and the computer pulls timing.  1000 more times on your trip to the mall and back.  You don't think that will take toll day after day, month after month, year after year?
I don't know more than everyone else, I paid attention and learned it here.  You can too if you do your research.
Last time at the drags I took a video from inside the cab, from the stands and took a Snapshot with my Tech-2 to show you guys that the motors do knock and you cannot always hear it.  I am not tech savvy enough put three videos into one but someday my kids might slow down and help me post it for y'all.
Myself and others have posted videos from youtube of 6.2s that came apart because of prolonged use of low octane gasoline.
  • Like 7
I went to tech school first for automotive technology, and then for a BSME. I didn't learn what I did from a message board. If you aren't under heavy load, cylinder pressures aren't enough to cause detonation. No manufacturer is going to sell a engine today that a slightly lower octane will cause them warranty work. But yes, you know more than everyone who has shown this isn't the case because someone posted a forum topic on "muh 87 causing detonation, omg."
  • Thanks 2
  • Haha 2
last year I rent a Cadillac Escalade with 6.2 to go on a long trip and yes if you use 87 in that ****** she will knock , I have heard it knocking , those 6.2 do not like 87, 89 was much better but she love 91 and above.
If it was going to damage the engine to use 87, then 91+ would be required vs recommended.
Well, you know so much that isn't so.
Make sure you let us know when you sell your car so we can all avoid it.
https://pickuptrucktalk.com/2020/10/misleading-these-trucks-recommend-or-require-premium-fuel/#:~:text=GM recommends using 93 octane,economy you must use 93.
Recommends and Requires do not have the same meaning.
Question! As GM's RECOMENDED 93 is not available everywhere in the USA does that mean those who live in areas without 93 can 't own a 6.2? :dunno:
Kiddo's my little much hatted by most 4.3 RECOMMENDS 87 octane and pulls up to 10 degrees KIR on every hill or major headwind. It's also a Flex Fuel vehicle and pulls zero KIR when using something over 40% ethanol and more interestingly does about 3% better that the carbon balance would indicate which speaks to GM's claims the RECOMMENDED USE of higher octane fuel will ENHANCE PERFORMANCE AND MILEAGE.
IF KIR knocked rings out of motors there would be heaps of dead 4.3's littering the highways.
Does that mean others observations of damage are in error? 🤔 Absolutely not. Some knuckle heads think towing heavy on 87 is a good idea and they will suffer for that mistake. KIR will not pull an infinite amount of timing.
  • Like 4
    iso221
    iso221
  • Who's Online   6 Members, 0 Anonymous, 500 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
