Went to the dealership expecting to grab a new grille for $400-$500. Instead found out that the grille is $1800CAD and there is no stock or ETA from the manufacturer as it is on back order.
I slammed on the brakes and grill took majority of the impact. I saw the deer go up 10-12ft and land in the ditch. I was expecting my front end to be smashed as well. Guess I got lucky and thank god the air bags didn't go off, as that would've cost more.
I would say part being made is going towards producing new trucks to get inventory back up. Parts are pretty much tough to get for anything still. If that is all the damage you got I'd say you did good.
Damn, sure it wasn’t a cat. I had a 61 super 88 tank back in the day look worse than that after a deer strike. My only time.
  • Haha 1
Yea that's what I figured. The dealership said I'd be looking at 2-4 months for the grille. He said if it was 4-5 weeks it would show in the inventory.
I called most of the GM dealers in Canada, and the ones who had this grille on hand, they were holding it for the body shops.
I tried to see if I could get the elevation or vader chrome grille off the Denali Ultimate lol. Same issue.
It was a fully grown deer, and I was doing about 110km/h (~65mph). It was about one second when I applied the brakes and hit the deer. So I had slowed down to maybe 60kmph. And I hit its ass end, as it was mostly off the road. But it still managed to get airborne and land in the ditch.
My 2008 Benz C350 didn't fare as well as yours.. and it was a baby deer while I was going 90 km/h. $4,500 in repairs. it sucked because the car was only two or three weeks old.
Edited by Wiggums
Yeah those days ended back in the 1990's, i don't think there are many parts on the front end under a grand or two except maybe the bolts and emblem.
Poor truck. But did you pick up the road kill... That's wasted venison.
Man, you got lucky that it was just the grill. If it was me, I would have the whole front end smashed in given my luck
Edited by 20Denali22
IDK about the Lone Star State, but in many localities you're required to contact the game dept. or state patrol whom will see that the venison is donated often times ending up in county lockup kitchens. Since an accident report is needed for an insurance claim, the state patrol (or in the case of the OP the RCMP?) would be the logical choice.
Edited by garagerog
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
