23 hours ago, ember1205 said:
Nope. This is from the 2024 manual, but same Turbomax engine.
Good to know, thanks
I drive a 2.7ho and a 5.3 both 2022’s both now  have just over 30k miles. I personally like the 2.7 better, it feels more responsive. The 5.3 gets 4 to 5 mpg worse mileage. I have had no serious problems with either. The 2.7ho pulls a trailer just as well as a 5.3 and might have a slight edge mpg wise but the lead shrinks here. If the 2.7 makes it to 250k without a major malfunction I will be happy and classify it as better than the 5.3 but that has yet to be seen.
Does your 2.7 use oil?
The 2.7 might get the jump on the 5.3 to 30mph but the 5.3 will start pulling away and get to 60mph a second faster and will continue to widen the gap into the 1/4 mile. The 5.3 also will perform way better passing at highway speeds, the 2.7 runs out of breath in the higher rpms and at passing at highway speeds. If you're mostly a local city driver, then yeah, the 2.7 works, but if you're a mostly highway guy like me, the 5.3 is the way to go.
Edited by Diamond817
On 11/30/2023 at 4:57 AM, Mshawn said:
Work and back is 80+ miles for me and I’m getting 22-23 consistently with my 5.3 and I’m a crew cab z71 5.3 L84 all interstate though.
Update: work and back is up to 26.4 mpg with a 4wd z-71 5.3 what other 1/2 ton v8 4wd can do that?
With a lift, AT's, and removed front air dam, my Z71 is  getting around 21 mpg on the freeway doing 75-79 mph.  If I drop the speed down to 70 mph, I'll get 22+ mpg.  Current odometer reading is 120K+
I own a 2.7 HO, came from a 5.3 before it.  Never had a "run out of breath" scenario with the 2.7 HO vs my 5.3.
Edited by newdude
doubt.
1 hour ago, fondupot said:
doubt.
Actual/Calculated? I also doubt it.
Guesstimated by the crappy algorithm in the truck and displayed in the dash? Maybe.
My last truck consistently showed at least 1MPG higher than actual.
Punch it when traveling at 75-80mph, let me know what happens. The 5.3 takes off like a rocket, the 2.7 falls flat on its face. I test drove both extensively before buying. Again, if you're a city/local driver the 2.7 works, but that's where it ends.
I agree with this. I’ve driven both. My 2.7 feels fine around town. Torquey and peppy. But on the highway the passing power really lacks compared to what a 5.3 has.
The 2.7 is fine for cruising at highway speeds tho. Just not good for passing power.
Good example of the difference between torque and horsepower.
Real world fuel mileage with the hammer down, like you apparently like to drive, is not appreciably different between the 2.7, 5.3, and 6.2. There are decisions to make in life. If you want fuel mileage in a GMC, the 3.0 diesel is for you. Trucks are not pony cars,but If you want the sense of acceleration, it's the 6.2 with active exhaust. Or stay with Stellantis and look at the Hurricane SST HO for the '25 Ram 1500; 500 hp and 600 ft lb.
https://youtu.be/ji4OD31rBaI?si=Wx-TWYx0ma3KlLef
https://youtu.be/jSVg06mGiWI?si=MS8KRTkjUkw5UT-a
Edited by MaverickZ71
Maybe for the pre-refresh.. My 22' with the HO version takes off at 70-75 when passing other trucks. That's with 35's. Def does not fall flat on its face whatsoever, and thats when pulling a decent grade in heading up north from Phoenix. So maybe flat the V8 can pull it. But ill take the extra torque when it matters.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
