2500HD OR 1500
12 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
2500 or 1500…. I currently have a 1500 6.2l but find myself wanting (not necessarily needing) a 2500HD diesel. Heaviest thing I’ll tow is a wake boat a couple times a year.
Edited by aha1987
How much are you wanting to spend?
Do you care about fuel mileage or that fixing stuff on a 2500 truck costs way more when stuff does need repairs?
Half tons can tow just about anything for most people, just heavier weights over 9,000lbs in my opinion get sketchy and a 2500 is way more stable.
I agree with Cam. Are you looking at a diesel? The 3.0l diesel is far more forgiving than the 6.6l diesel is for driving empty for issues with the emissions systems.
The one big advantage of the 2500/3500 trucks is they are designed to operate at or near max load all the time and 1500s are not. If you were towing above 8000 or 9000 lbs then a 2500 would be a better choice, the brakes are much better on the 2500/3500 for stopping a load if the trailer brakes fail.
I agree with Cameron, I had a 2004.5 2500HD with the lly Duramax motor as I used to pull boats some were from 18 to 36ft but after I stopped pulling boats I couldn't justify keeping it just to pull a 18ft boat and a utility trailer so I went back to a 1500. You say it's not necessary to have one then keep your 1500. 2500 trucks get about 12mpg unloaded with the gas motor.
My 2015 5.3l half ton got exactly the same mileage as my 2018 L5P 1 ton.
Empty OR Loaded
The half ton was FAR more comfortable. The 1 ton is FAR more capable.
So far the operating costs are essentially the same, except having to buy DEF.
I value the capability more...
Do you know roughly how heavy the boat and trailer are you have now?
Split the difference, max tow 3.0 diesel, IF you can find one.
Your regular driving MPG would go up a fair bit over both a 6.2 and an HD Duramax.  Towing, everything gets 10-12mpg pretty much.
Now, if you've got plans for a bigger boat, camper trailer, or any increase in towing, I'd steer towards HD for sure because brakes, payload, axles, engine, its all much stronger.
Edited by newdude
I drive a Z-66 avalanche with the towing package. Last week I drove my brothers FX4 diesel Ford. Its bed was loaded with a toolbox full, a 50 gallon fuel tank full, an air compressor, a couple of coolers spare parts etc. I’ve owned 3/4 tons for pulling, nice ones. My brothers is fully loaded and very nice. It was rough enough that it tired me out after 4 hours. I was glad to finish my drive home in my avalanche. The avalanche is rough for a half ton. In conclusion I wouldn’t buy more truck than I need if it was used as a daily driver.
It's dumb to have an HD if you aren't towing at least 7k lbs on a somewhat regular basis.  HDs have higher operating costs, take up more space, and waste more of everything...so you really need a good reason to own one.
This is like asking what oil should I use.
  • Haha 1
1500 with a 3.0.
Don't need max tow for the job you are describing.
TC10543 is 2wd crewcab shortbox
TK10543 is 4wd of same
It's not wise to place yourself into the DEF/DPF modern diesel emissions nightmare just because. Also nobody has mentioned that the HDs ride like covered wagons. My wife can barely get a sip out of a cup without wearing it on a smooth road and I'm on 37s with 18s (lots of sidewall) at only 45psi. 3,500+lb payloads have savagely stiff springs that sailboat fuel can't compress. Shocks are practically worthless empty (I have driven with only 3 with no change).
Sound exaggerated? Good. Because people justifying their purchase from the other point of view will tell you how it rides great and blah blah. It scientifically can't. Again, torsion bars and 3,500+ payload leafs don't compress willy nilly.
Cheers.
just keep your 1500, you answered your own question right from the get go
its an ego thing.....
humans complicate their life and justify why, its normal
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
