I am preparing to replace my current tires. My gut says replace with Michelin ltx as2. We do take a lot of ungroomed dirt roads, nothing extreme while towing. I have a 2019 GMC 1500Denali. Really only 2 other choices with a load rating of 115 or more. The K03 and the DUELER A/T ASCENT. The K03's might stiffen the ride, and while towing wouldn't break my heart. I know the Denali is designed for a smooth quite ride, not worried about noise. I already upgraded the exhaust, so it is a little throaty.
I would love some input.
I replaced the stock tires on a 2020 with Michelin Defender LTX M/S 265/65/18. I have them on over two years, 99% city/rural paved road driving. I do not tow or haul heavy loads. The main reason I swapped out the stock was to improve wet traction. No constant wheel spin on wet roads now. I purchased at Costco, really can't beat all the extras as annual balancing, rotation etc. I think they have free installation now also. I have never used Dueler or KO3 so no opinion on them.
My opinion from being in the tire business for the past 15+ years is not to run a LT tire if you don't require it.
The KO3 is a good tire but they cost way too much and they only come in LT's, so they are heavier and will slightly reduce ride quality and for some fuel mileage.
The Michelin LTX are great tires but again a little spendy. Other really good options are the Nittio terra grappler like posted above, the Toyo Open County AT3's (I put those on my Moms Silverado), Hankook DynaPro RF10 or RF11's I think.
There are other cheaper tires that I know are good tires too but most people have not heard of them or may not want to use them as the tread life won't be as long compared to a higher end tire. Again it always comes down to budget and what people use the vehicle for. Some of those tires may last someone really long time if they don't put on 15k miles a year like some people do.
I've been putting the Michelins on my truck since 2003.  I couldn't wait for the stock Bridgestones to wear out - they are garbage in the wet.
I put KO3's on mine and they ride great. Better in the rain that the stock GY tires were. No noticeable drop in MPG either.
Pomps?
I swore I wouldn't use anything but the BFG All Terrains on my trucks - except I don't like the slightly tighter tread pattern on the KO3 vs KO2. I'm leaning towards the HD Terrain.
There are other cheaper tires that I know are good tires too but... or may not want to use them as the tread life won't be as long compared to a higher end tire.
This struck me as odd, because tread life is part of what makes a 'good' tire to me.  Not arguing, calling you out or insulting...
I'm more so talking about tire that come with 45-50k mile tread wear life compared to others that say 60-65k. And honestly unless you only drive freeway and never scrub your tires around town, getting 65k+ real usable miles out the tire is on the slim side. Where I live a tire is basically useless at 5/32nd when it comes to winter.
Alot of these tires can cost hundreds of dollars less per set and if you don't put on 20k a year, they can be worth the buy. You'll still get 5 years easy out of a set of tires.
Edited by CamGTP
That's a you thing lol.
Around here it just doesn't happen that often for most tires, not with our climate and dealing with snow. Tires will still have tread on them and look okay but they will still be useless in the winter. It kinda sucks because if it was summer you'd still have another 10k of use with them.
Same here. Went with the Michelins as soon as I could justify it.  Probably left at least 10K miles on the stock tires, but I’m happy with the Michelins.
I replaced the good in the dry but awful in the wet and winter conditions oem Bridgestone Dueler at. With the Bridgestone Dueler AT Ascent. After 3000 miles since early October and finally driving around in a nasty winter storm 2 weeks ago that had up to 10 inches of snow along with mixed freezing rain and sleet that I drove around in for 14 hours this tire is freaking awesome. It’s way better than the tire it replaced.
My '22 Sierra came with BFG KO2s from the dealer and, looking at the tread pattern, I assumed they would be awful in the rain. I was wrong they are the best AT tires I've ever used and I've used alot of them since 1989. They do not break traction on a wet road they are great. On my '14 Silverado that I traded in, I was running Toyo Open Country. They were pretty good on wet roads but would break traction occasionally. This was the 2nd set of Toyo's I ran on it. The 1st set was identical and I was determined to get 60,000 miles out of them as that's what they're rated for, so I just kept running them and I did get to 60,000 on them, but they were bald and borderline not really safe to run at that point I should've replaced them sooner. The worst ones I ever had were Uniroyal Laredo's and those were dangerous in the rain it's a wonder I survived to get 40,000 miles on them before I replaced with GY Wranglers.
    • I just bought this. A minimum for me but, I don`t work anymore and don`t want the heavy update costs of the higher end tools. You would have to make money with them.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Even this tool has a $250.00 update cost after 2 years.
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
